WTB steering rack
Old Aug 27, 2002 | 11:18 AM
Levi's Avatar
Default WTB steering rack
I am looking for a replacment for my leaking power rack.
I assume I could use any 87 rack?
Anyone have a good one FS? I can give a core also.
Anyone know if fixing a leak is possible on these. It appears that one of the seals is leaking out, not bad, but leaking.
Another question: Can I make the car manual? Can I connect the lines together and leave some fluid in it and use it this way? Or is it a real bitch to turn? will it lock up on me?
I have done this my power rack on my RX7 and its not bad, and wonder if it can be done to my car?
custom parts is our perfection.
Old Aug 27, 2002 | 11:23 AM
mpbiv's Avatar
Rod Bearing Eater
I have been driving my K around with the power steering pump disconnected for months, and I have done this before no ill effects. This is my second leaking rack, except mine basically losses all fluid within 3-4hrs and leaks at both boots.
I am thinking I will just replace it with a fast ratio rack from a C/S Package Daytona, apparently you can get these remans at any auto parts store and I doubt they will know the core is not the same.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Aug 27, 2002 | 11:24 AM
mpbiv's Avatar
Rod Bearing Eater
Oh its not that bad to drive without power assist. Actually it seems easier to drive than my sisters Hyundai Hatch with has a manual rack in it.
Patrick
Old Aug 27, 2002 | 11:25 AM
Levi's Avatar
Can you explain a little more to me?
You just took the belt off?
I wanted to remove the pump and the lines, and then run them together to allow fluid to move back and forth some, to maybe make it easier to steer.
I just noticed something, if its leaks, it would go empty sometime, and then lock up right? I guess leaving the pump on would be an easy way to keep fluid in it. I lose about 1/8 quart every 500 miles.
Old Aug 27, 2002 | 11:29 AM
mpbiv's Avatar
Rod Bearing Eater
well it won't lock up, other wise mine would have a long time ago. but you probably should leave the pump, as a quasi funnel to keep er lubed
Patrick
Old Aug 27, 2002 | 05:38 PM
flybyuin2.2's Avatar
go to Cophers and pick up a manual rack out of a Omni and lose the P/S pump for good
Old Aug 27, 2002 | 06:06 PM
CrazyMoparGirl's Avatar
Guest
I have a manual rack for a "L" body but it isn't for sale. You might get lucky at garlits later this year, if not I can have 808 look at the junkyard when he goes this week.
Old Aug 27, 2002 | 06:36 PM
yeah, they're probably not so easy to find here in FL
Old Aug 27, 2002 | 06:57 PM
Guest
I got mine in Seminole, from the guy that originally sold me my Omni
