WTB steering rack
Old Aug 28, 2002 | 01:23 AM
whore's Avatar
greg...
Old Aug 28, 2002 | 01:24 AM
whore's Avatar
Originally posted by "flybyuin2.2"
yeah, they're probably not so easy to find here in FL
Wouldnt bet on that. I find tons of non a/c cars here. I just never look in L's for many things and especially not manual racks. I can though.
Old Aug 28, 2002 | 07:08 AM
leadfootedfool's Avatar
Eat soot
Originally posted by "Levi"
I wanted to remove the pump and the lines, and then run them together to allow fluid to move back and forth some, to maybe make it easier to steer.
Not recommended, I'd just disconnect the lines let all the fluid pump out, then just seal it. If you leave the fluid in the rack without the pump it's pretty hard to steer.
Old Aug 28, 2002 | 08:19 AM
4sfed 4's Avatar
4SFED4
Default Re: WTB steering rack
I dont think it will lock up, however manual racks have a diff ratio to make them easier to turn. 4SFRED4 can comment on the turning. He had it like that on the GLH
Hey....why you calling me FRED?
Yes, you can just run a hose from one port on the rack to the other and get rid of the PS lines altogether and it will work fine. The wheel will just be harder to turn I didnt try draining the fluid (as suggested above), but that might make it easier to turn.
Old Aug 28, 2002 | 08:40 AM
mpbiv's Avatar
Rod Bearing Eater
It may be harder to turn with the fluid but you might still want some in there for its lubrication purposes. Besides a little upper body workout couldn't hurt
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Aug 28, 2002 | 09:40 AM
whore's Avatar
, because now that you're a regular here again, we need to start having fun with your name. Like MauRICE and 8r14n
Old Aug 28, 2002 | 09:43 AM
  #17 (permalink)
Eat soot
True dat, long term with no fluid might not be such a hot idea.
Old Aug 28, 2002 | 09:47 AM
  #18 (permalink)
whore's Avatar
or a cool one
Old Aug 28, 2002 | 08:56 PM
  #19 (permalink)
CrazyMoparGirl's Avatar
Guest
Originally posted by "whore"
greg...
Jup
