All about the wonderful 2.0l 4 cyl engine!
Guest
Posts: n/a
heres what I know.
Talons/Eclipses came with both turbo and nonturbo 4g63 2.0L 16v dohc mitsy engines
I believe maybe the 2nd gen non turbo ones came with the 420A engine. Some of them did at least..
The 2.0 that was in the neons is most likely a dodge engine because the block is very similar to the 2.2/2.5s. I dont know if thats the 420a or not.
I believe the 2.4s are spawn of the 2.0.. probably just stroked like maurice said.
Moreover since Dodge is one of the big 3 (if you still wanna call it that) we get to make all the rules
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Patrick
Guest
Posts: n/a
The DOHC 2.0L is a dodge motor. We have one in the garage. The 2.4L is a dodge. the 2.0 and 2.4 have in common MOL what the 2.2L and 2.5L have in common. Well the 2.4L is about 1 inch taller than a 2.0L. Walter remember Johns Neon with the 2.4L they had to tilt the engine back to get it to clear the hood. He also used the 2.0L intake. The head is the same also. I am not sure about the Mitsu versions as I have asked this before with no luck.
Ok so here is how it pieces together.
1) All neon engines are made by Dodge
2) The DOHC Avenger engine is exact same as NA Eclipse and are made by Mitsu.
The other night I was pretty sure the 2.0 DOHC was the same exact engine in both the NA Eclipse and Avenger. Then I went and looked at someones site on NA eclipses and now I am undeniably sure of this after seeing a pic of the engine in the eclipse. I already knew what the 2.0 DOHC in a Avenger looked like because my friend at school showed me his engine when he got headers and the motor is identical (I think even the valve covers are identical down to the lettering).
Patrick
Patrick
so the question left to answer:
the na eclipse with the 2.0 l motor is that a neon motor?
All of the DSM guys say it is. Im not too sure after reading all of the posts here.
Guest
Posts: n/a
