more problems with Srt 4
Old Oct 12, 2008 | 09:00 PM
wild_srt4_driver's Avatar
srt4 driver
Angry more problems with Srt 4
ok this car is really starting to piss me off i just was having problems with the crankshaft sensor keep failing so i replaced it and now i throw another code of Crankshaft Position Sensor A Circuit Malfunction so if anyone has any ideas for what i should do on this one also let me know or had the same problem and fixed it plz let me know thanks
Old Oct 12, 2008 | 09:56 PM
ExPlOReR_oN_DuBs16's Avatar
no clue on that one......did you just buy it?
Old Oct 15, 2008 | 12:55 PM
srt4 driver
i bought it awhile ago like 2 and a half months ago
Old Oct 15, 2008 | 01:37 PM
The Mayor's Avatar
Only does digs!!
make sure none of the wiring was stripped and touching anything. also check to see if its a stage 1 or stage 2 ecu. they tend to throw stupid codes for no reason
Old Oct 17, 2008 | 05:18 PM
cali's Avatar
Skittle on crack!
sounds llike wires broken or maybe reversed...
You can quit watching me now....
Old Oct 18, 2008 | 04:11 AM
so about that hood............lol
Old Oct 21, 2008 | 10:18 AM
treekiller's Avatar
legend behind the cowl
yes, sounds like the sensor was fine, you have to do a little wiring harness investigation. do you have a shop manual or wiring diagram? if not PM or call me, I can help. 813-333-1100. if a dealer finds a dead short in your harness he's gonna want to replace the harness, so to fix it on the cheap, run some new wires or bring it down and I'll check it out for you.
Old Oct 22, 2008 | 12:28 PM
christi3435's Avatar
Check the harness that goes around the head under the manifold to the sensor. They tend to wear and short things out. Also sometimes it's not the CPS but CMpS (cam sensor). The run on the same circuit and could annoy one another. I would definitely check the harness though..I have never heard of a staged PCM throwing random codes for no reason.
Base 4D, 2.4L swap, 2.0 cams, SRT turbo, 52mm TB, gauges and 3.0 unmodded intake, BOOGERS! and Megasquirt! 250Hp to the ground.
Old Nov 8, 2008 | 04:10 PM
Steve-O's Avatar
Fiat Specialist
Check all your spark plug wires and the plugs themselves. Pending on the manufacture date some of the plugs and wiring can be faulty. and cause other issues to arise making it seem like something else.
Any plug or wire that is faulty will cause a misfire in a cylinder if your having idling fluctuation.
let me know what you find
Old Nov 14, 2008 | 09:27 AM
flykidof08's Avatar
g0sh darn ricE burNers!i!
i had the same problem with my sxt..
i took it to the dealer and they fixed it.. they said their was a shortage in the wireing system.. it suckz cuz i paid 100 bucks for them to do it..
