need help on a Srt 4
when i'm driving my 2004 srt 4 when i go to shift sometimes the rpm's will hang at 2000 rpm's and wont drop till i put it in the next gear and let the clutch out and i was throwing a code so i checked it and it was a crankshaft sensor failure so i replaced that and its still doing the rpm hanging but no codes now would anyone have any suggestions to what this could be or what i should try to fix this annoying thing but other then that the car runs great
Reset the ecu.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Could be a common twitch is why he said that. Also the IAC could be hanging.
Base 4D, 2.4L swap, 2.0 cams, SRT turbo, 52mm TB, gauges and 3.0 unmodded intake, BOOGERS! and Megasquirt! 250Hp to the ground.
