head studs
Old Feb 10, 2006 | 12:47 PM
HPNOTIQracing's Avatar
Default head studs
im running just about 14.1-1 compression and i im getting headstuds. will oem be sufficiant or should i go with arp or something and why?
Uploaded with ImageShack.us
Old Feb 10, 2006 | 01:13 PM
Josiah's Avatar
Peon on steroids!
14:1 compression? is that even possible? the most I have ever seen in a neon or 420a engine is 13.5:1 and I would DEFINATLEY suggest headstuds at that cylinder pressure, (although on second thought boost probably creates just as much pressure and headstuds arent needed for it)
Old Feb 10, 2006 | 01:39 PM
i have 12.5-1 pistons decking the head .045(.045=1.125 points of compression. ) 13.625-1. i was contemplating removing the middle layer of the headgasket which gives it another half point
Old Feb 10, 2006 | 03:13 PM
Josiah's Avatar
Peon on steroids!
careful of valve clearance then, otherwise you may have an unpleasant surprise...I say keep the middle layer, 13.6:1 compression is enough(your starter will thank you)
Old Feb 10, 2006 | 04:46 PM
yeah the middle layer was a possiblility. but im puttin tomuch money into this bitch to try and risk this shit. yeah and do they sell a stronger starter if the stock cant turn it over? also do you think 93 will be high enough?
