Voltage regulator quesrtion
Old Mar 19, 2004 | 08:03 AM
Levi's Avatar
Default Voltage regulator quesrtion
Where is the voltage regulator located? Is it inside the alternator?
Mine has gone bad, but the alt tests out good..
please help..
custom parts is our perfection.
Old Mar 19, 2004 | 11:44 AM
Clint's Avatar
keyboard hardass
What car is this again? Omni GLH?
I can't remember, but if so...
Once upon a time, the Dodge Omni line of vehicles had a nice little voltage regulator mounted somewhere on the firewall that was fairly easy and inexpensive to replace. This apparently all changed with fuel injection in 1990, when the voltage regulator was moved into the onboard computer. Effectively, what would otherwise be a $30 part becomes a $300 part.
YMMV
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
Old Mar 19, 2004 | 04:15 PM
Levi's Avatar
I have a Shelby Charger GLH-S, and I don't have that box, I looked. Do you think it may be in the alt?
Old Mar 19, 2004 | 07:49 PM
flybyuin2.2's Avatar
Levi, the power module(the black computer next to the battery)
it controls the charging system.
Old Mar 20, 2004 | 04:01 AM
Levi's Avatar
Damn it that thing, that air flows through is shot?
How can I test it Mike? I tested the car on the alt test and shows not enouigh voltage, remove the alt and tests good @ the shop..WTF power module again.
Old Mar 20, 2004 | 09:13 AM
Power Module or fusible links are melted, bad.
Old Mar 20, 2004 | 02:03 PM
Levi's Avatar
Would that make all my guages dead? the tach is dead also, this all happened @ the same time, when I noticed the car misfiring and voltage was reading low, then bam, all dead. but car ran kinda... Do you have a module that works FS, and if not will any turbo module work ? give me all the details brother teach me..
Old Mar 21, 2004 | 04:36 AM
4sfed 4's Avatar
4SFED4
Levi-
To test the alternator and narrow down the problem, apply +12V to the field terminals (the two small wires going to the alternator). If the alternator output voltage jumps way up when you do that, then the alternator is good and the voltage regulator/field wiring/power module is bad.
Larry
2002 MB C320 Sport Wagon 15.4@91
2002 Dodge Neon SE
1991 Dodge Spirit R/T-12.3@117 (at 368 whp) Now 500 whp / 514 ft lb on pump gas
Old Mar 22, 2004 | 04:52 PM
Levi's Avatar
so that enitre box thing on the side needs to be replaced. Just to make sure it the box that air should be draswn through with stock air intake setup?
How much do those go for?
Can I use anyone, or does it have to be for a Shelby and Turbo?
I found one on a 84 charger carb, does carb matter, for what this one part does?
Old Mar 22, 2004 | 04:55 PM
Levi's Avatar
Thank you for the help\ Larry and Mike. Long live the Shgelby Dodges guys~!!!!!
Does Jefff still have his CSX? and that 4 door sleeper.
