Chassis & Suspension Tech Cages, braces, suspension set up and more
suspension sugesstion!
Old Mar 30, 2009 | 05:02 PM
mightymouse0630's Avatar
Default suspension sugesstion!
so i have a 1995 ls integra with a gsr turbo swap. im looking into to buy a good suspension setup. what is a good setup to run that is decently priced.(i dont want shit but i also dont want to spend 2gs on coilovers) thanks for the input
Old Mar 30, 2009 | 05:51 PM
Loren's Avatar
You want suspension that is "good" for what?
Drag racing? Autocross? Road racing? Off-road use? Highway cruising? Scraping speed bumps? Impressing people who think "low" is cool?
Old Mar 30, 2009 | 07:57 PM
Rallek's Avatar
Apexer
Nevermind the grumpy old racecar driver. Though he does have a good point. And when you do answer his questions, listen up. Cause Loren knows suspension.
As a rule of thumb, drop springs will get you the look, shocks will get you the performance. Either way, getting all that power to the ground is something you should aim for.
Jerry kellaR - Sonic Blue '05 Mustang GT
12.96@108.1mph(Bradenton)
310 rwhp 323 rwtq (Pete Stop)
Old Mar 30, 2009 | 09:18 PM
its a daily driver. i had a set of kw fully adjustable coilovers on my srt-4 that i use to own and i was really impressed by them bcause not only was it a nice looking drop it also drove really smooth and had nice performance, thats what im looking for. kinda an all around daily driver with a nice look but not slammed good performance but not drag or autocrossing
Old Mar 31, 2009 | 06:37 AM
Loren's Avatar
Talk to Jeff and see if K-Sport makes a kit for it. You could go with a set of springs and shocks, but then you're stuck with whatever ride height you end up with (most likely too low), and the shocks won't be matched to the springs. A low-end coilover kit like the K-Sport is a good value and gives you a lot of flexibility to set the car up at a ride height that works for you and adjust the damping for your personal preference between ride quality and handling.
The key to daily driving comfort is to retain some ride height and suspension travel to soak up the bumps.
Old Mar 31, 2009 | 07:29 AM
aight man thanks alot for your help
Old Mar 31, 2009 | 10:46 AM
treekiller's Avatar
legend behind the cowl
yea The K-sports are availble for that application and they are priced right $799 Keep i mind K-sport is full length adjustable unlike some other kits. which allows the hondas to be run low without loosing travel. and while I don't disagree with Loren often.. the older Hondas can be run pretty low and actually work "in the weeds"
Give me a call if you want me to order them since k-sport needs 2 week lead time.
Old Mar 31, 2009 | 11:13 AM
Tallgeese0721's Avatar
ii hito Kei
Might i recommend a set up that works excellent for me... Skunk2 adjustable coilovers with Koni Yellow adjustable struts. I have it on a 92 hatchback. The ride is quite civil (given I have the Integra version of the coilovers) with the Koni's on full soft. And when I autocross or do some "spirited driving", they give me the stiffness I need. Plus, the ride height is adjustable. In my opinion, I've found the balance between sport adjustability and daily driveability. Just don't slam your car like most of the Hondas. Give yourself some suspension travel. I have a nice lowered height, but I rarely scrape the front lip and go over train tracks with ease! Hope my experience is worth something.
Old Mar 31, 2009 | 05:00 PM
thanks i really appreciate it. im def going to go with the skunk2 coilovers, thats what i had in mind. thanks again for you input
Old Mar 31, 2009 | 06:28 PM
ii hito Kei
np. Just remember, as Rallek stated, shocks will get you the performance. At the very least, get Tokico blues. They're better suited to handle the stiffness of the skunk2 coils than stock used struts. If you can't afford those, KYB GR2 will be alright for a little while.
