Sick car I need help!!!!
Hey guys My car is making a strange sound under load it sounds like a rod knock to me but I am not an expert. Is anybody over in the Ulmerton and 19 area (I work about 5 minutes from johns shop) or plan to be later? I would appreciate it if someone else could listen to it and let me know if it is even safe to drive it home or up to Z. Hills were I will prolly end up spending all night slaving to get my truck running so I can park my car till i can afford the repairs.
Please let me know asap.
Thanks Walter
Thanks Walter
Originally posted by "Someone"
Originally posted by Mr Self Destruct
Walter Ill be at the shop tonight starting at around 6. Stop on by ill diagnose it for free.
First just run a vac and compression test thatll tell you a lot right off the bat. And like I told you the other night check out your plugs especially three as it tends to show conditions better. Another good idea is to listen to the engine while it runs with a stethescope. If John doesnt have one on hand you can just use a long 3/8 extension (hold it to various areas of the block and put your ear against the other end).
Id offer to help you out but Ive got two midterms to study for. If you still need a hand come Friday drop me a line since Ill be done with them then.
Does John work on fords? I think Im losing compression in cyl 1 or 3 it may just be running lean cant really tell but it just feels like its losing what little power it had in the first place.
This Space for Rent
This Space for Rent
Thanks for the info Bill.
I am almost 100% sure its a rod knock just ask Taylor what it sounded like on the way across the howard franklin. I swear Ive only driven slower across that bridge one other time and that was when I got a flat tire while crossing the bridge.
On the bright side I dont have any excuse to wait on rebuilding the motor with various aftermarket internals
Youre positive the noise isnt from the suspension or tranny?
With the car in nuetral and throttle applied can you still hear the noise?
Rod knock is not a nice sound to hear...to make absolutely sure that its not rod knock check your wallet. If money is being sucked out of it before your eyes then its definately rod knock...
Guest
Posts: n/a
1v3 l1573|\|3d 70 ju57 4b0u7 3v3|2y p0551bl3 p|20bl3m 0|\| 4 B 53|2135 m070|2 f|20m \^/0|2|\| v4lv3 5p|21|\|g5 70 b3|\|7 v4lv35 70 b|20k3|\| |20d5. 7h15 15 \^/17h0u7 4 qu35710|\| 50m37h1|\|g 1v3 |\|3v3|2 h34|2d b3f0|23. 7h3 0|\|ly p|20bl3m 1v3 |\|3v3|2 3|\|c0u|\|73|23d 15 4 5pu|\| |20d b34|21|\|g 50 1m g01|\|g 70 h4v3 70 gu355 7h475 17. \^/17h 7h3 c0|\|d1710|\| 0f h15 01l 7h3 4g3 0f 7h3 m070|2 (100k+ m1l35) 4|\|d h15 d|21v1|\|g 57yl3 175 4 h1gh p|20b4b1l17y. 7h3 0|\|ly 07h3|2 7h1|\|g 17 c0uld b3 15 7h47 m1551|\|g v4lv3 l45h |\|u7...\^/3ll 533 500|\|.
Hey John If you have some time I would really appreciate that list we were talking about gotta start planning. Ive already written an email to Endyn just waiting to hear back from them now.
BTW It is the most disturbing sound I have ever heard my car make the drive in to work this morning sucked hardcore I cant hold a steady speed above 45 mph. to go faster I have to constantly speed up and then slow down to keep it from sounding like a highschool percussion group.
I agree with John I think I spun a bearing based on the sounds its been making for the last week or so before it started knocking.
