BMW / Mercedes Tech Germany and its finest
i'm having a problem with my bmw and need help
Old Jun 5, 2009 | 06:32 PM
  #21 (permalink)
jriggs's Avatar
is better than you™
Originally Posted by chondacrx
it you take the radio fuse out the brake lights go off and work like they should. anybody have any ideals.
sounds like a wire has become frayed causing a short across the electrical system. bmws can be a little finicky with there electronics. try pulling the head unit put the fuse back in and see if the problem still exists
Originally Posted by IRCFlorida
You need a Turbo/Intercooler kit my friend
isn't it a better idea to get cars in proper nothing wrong order before aftermarket performance?
Old Jun 5, 2009 | 10:44 PM
  #22 (permalink)
lutzperfautoinc's Avatar
isn't it a better idea to get cars in proper nothing wrong order before aftermarket performance?[/quote]
Hey sometimes you work from backwards to forwards?
Andrew Congleton
-Lutz Performance Automotive
PH: 813-949-3540
Cell: 703-314-6511
Andrew@lutzperfauto.net
17510 US HIghway 41 N
Lutz, FL 33549
Old Jun 15, 2009 | 02:35 PM
  #23 (permalink)
chondacrx's Avatar
gangster
i took the head unit out today and it still goes it.... also when the brake lights are on the steering buttons doesnt work and when i turn the high beams on the radio cuts out for a second and comes back on....
Old Jun 15, 2009 | 05:05 PM
  #24 (permalink)
Jcapelo's Avatar
has your car been underwater?
R.I.P Kenny S. Capelo
11-14-83~~~~ 7-6-03
I miss u bro!
www.floridagerman.com
Old Jun 16, 2009 | 02:44 AM
  #25 (permalink)
chondacrx's Avatar
gangster
no
Old Jun 16, 2009 | 04:15 PM
  #26 (permalink)
huh radio? either your mistaken or you may have a tricky electrical problem!
Andrew Congleton
PH: 813-949-3540
Cell: 703-314-6511
Lutz, FL 33549
Old Jun 16, 2009 | 04:47 PM
  #27 (permalink)
chondacrx's Avatar
gangster
i was told it could be the ignition switch
Old Jul 3, 2009 | 12:30 AM
  #28 (permalink)
speedminded's Avatar
bmw just replaced the brake light switch acouple weeks ago and its still doing it so i'm not really sure whats causing that... thanks for the info on the cam sensor. is replacing the cam sensor hard to do.
A wiring fault in the rear lights is common but since yours is a '99 it shouldn't be effected by the service bulletin that is for Sept '01 cars and up. It's worth a shot.
Service Bulletin:
http://www.bmwtis.com/tsb/bulletins/...p/B630306g.htm
Bimmerwiki:
BMW E46 - BimmerWiki
Originally Posted by From Bimmerwiki
Tail lamp wiring faults. The updated E46 sedan (from 9/01 to 3/05 production) wiring harness has a design defect with grounding wires for the rear lighting that are too small and are made of poor quality materials, thus leading to wiring harness failure due to overheating. As stated in BMW's TSB, "Customers may complain that one of the rear lights is inoperative. CAUSE: Minor corrosion at the 8-pin rear lamp connector creates high resistance causing damage to the connector housing. CORRECTION: Repair the damaged wire(s) and replace damaged connector housing. Install additional ground wires to both left and right rear lamps." This can be easily confirmed by careful examination of the rear lamp wiring connectors which are usually melted. Symptoms include a "burned out bulb" warning in the instrument panel and (intermittently) completely inoperative rear lamp cluster(s). While BMW has a TSB for this problem, many have occurred out of warranty leading to arguments with the dealer (automotive lighting standards are Federally legislated, yet BMW refuses to repair this design defect once the cars are out of warranty). BMW dealers expect $350-$400, or more, PER SIDE to make the tail lamps work. As a result, check for a NHTSA recall (or a class-action lawsuit against BMW) before you pay for repairs. There are many threads on this problem; see the BMW TIS (search for SIB 63 03 06 if the attached link is inop)here. This problem was not limited to US market as you can read here. Cheaper DIY repairs can also be found on a variety of web forums, although your results may vary; here is one: here .
Car PhotographyMyspace2001 IntegraBMW e30 M52 GT30R
