BMW / Mercedes Tech Germany and its finest
i'm having a problem with my bmw and need help
Old May 27, 2009 | 03:47 PM
chondacrx's Avatar
gangster
bmw just replaced the brake light switch acouple weeks ago and its still doing it so i'm not really sure whats causing that... thanks for the info on the cam sensor. is replacing the cam sensor hard to do.
Old May 28, 2009 | 07:15 AM
Jcapelo's Avatar
Originally Posted by lennon
e36 or e46, the 323 is an m52 and yes it will fit.
They are different, the e46 has dual vanos which is a updated m52tu......Without doing some serious machining or modification it will not work.
Heres a link to guy from active that tried it and failed.
Tech junkies chime in! Intake manifold upgrade... - E46Fanatics
R.I.P Kenny S. Capelo
11-14-83~~~~ 7-6-03
I miss u bro!
www.floridagerman.com
Old May 28, 2009 | 07:17 AM
Jcapelo's Avatar
Originally Posted by Chris C.
no, '99 323 verts are e36's. I would know
He doesnt mention that his car is a vert....I am just assuming it is a e46 because that code is alot more common on the e46 then the e36.
But hey what do i know...
11-14-83~~~~ 7-6-03
I miss u bro!
Old Jun 1, 2009 | 07:50 PM
lennon's Avatar
e30 addict
guess i was wrong about the manifold. i thought id seen regular single vanos m52 in the 323.
every time a 24v e30 starts up, an e36 dies
Old Jun 2, 2009 | 01:43 PM
chondacrx's Avatar
gangster
it you take the radio fuse out the brake lights go off and work like they should. anybody have any ideals.
Old Jun 4, 2009 | 11:10 AM
IRCFlorida's Avatar
Default BMW Power
You need a Turbo/Intercooler kit my friend
Old Jun 4, 2009 | 02:23 PM
  #17 (permalink)
bam2002's Avatar
The radio installer did a crappy job and crossed the Amp wire or some other hot wire into the brake wiring?
Old Jun 4, 2009 | 04:12 PM
  #18 (permalink)
chondacrx's Avatar
gangster
everything is stock
Old Jun 4, 2009 | 06:09 PM
  #19 (permalink)
bam2002's Avatar
Was the stock radio always in place? or was it put back in at some point when the car was sold.
Old Jun 5, 2009 | 02:17 PM
  #20 (permalink)
chondacrx's Avatar
gangster
always in place
