Can I holla at some chain tech?
Go here and see if they have your application in stock. They advertise lifetime warranty.
SUPERSPROX USA
SUPERSPROX USA
Major props to Divine Sounds, Wheel Tec and Melilli Moto.
SUPERSPROX USA
SUPERSPROX USA
the chain breaker you dont really need, just grind one of the pins flush and it slides right out. if you dont grind it, you will most likely break the chain breaker lol. they are useful to flare the new link thou, but if you know what a good crimp looks like, you can use anything to crush it. i used a ball joint press tool i had laying around.
Ok got the Driven 520 15/50 steel with an RK gold chain. Taking suggestions on what to use to rivet the pins without a fancy smancy tool? Motomummy sells the replacement RK tool rivet pin for like $15. I was wondering about buying that and finding a way to make it work without the tool. I mean, it's not rocket science what I'm trying to do haha.
2008 R1 | 2004 ///M3
