Can't start when too cold?
Old Feb 13, 2010 | 07:33 PM
OrOr's Avatar
How fast officer?
Default Can't start when too cold?
I haven't ridden my bike since mid Jan. I usually start it every weekend and occasionally take it around the block. For some reason it refuses to start when it's really cold. It happened again this morning. I believe it was in the low 40s here last night? Everything seemed fine and it turns over as usual but I get no ignition. After several attempts of turning it over for 5-10 seconds it usually starts and runs perfect. Today I couldn't get it to start at all.
The battery is going on 4yrs old but it seems to be good. Gas is less than a month old and should be ok? Any ideas or is this a common thing?
Old Feb 13, 2010 | 08:22 PM
KISSmyACE's Avatar
TR Balla Donor Supreme
I know it is very common with quads, but they (most at least) are carbureted, and you need the choke to get it running. I know for every 15* of weather change, you need to move your jetting one increment. With Fuel Injection I was under the impression that the EFI box automatically adjusts to the temp. I'd assume it's no different with streetbikes?
Old Feb 13, 2010 | 09:47 PM
JH26's Avatar
ΜΟΛΩΝ ΛΑΒΕ
Batteries as reccomended by the dealer should be changed or have a life of 3 years. It sounds like maybe your battery is just old and the cold finally killed it. That or your battery just has a low amount of CCA's.
Old Feb 13, 2010 | 10:14 PM
_Will_'s Avatar
mi speeks gud
bikes are very voltage dependent, it may be cranking over just fine but not have enough to fire as well. I had the problem when my VR went bad and I kept having to charge it but your battery being 4 yrs old I'd say that's the likely culprit. check the voltage
Old Feb 14, 2010 | 09:48 AM
stealthc9's Avatar
have you checked the water in ur battery??
Originally Posted by Lime_Green_Hatch
i carry a gun because so many other losers and wanna be gangsters do.
Originally Posted by JH26
Morty,
The fact that I have red hair and no soul makes me very angry. I just wanted to let you know that when I swear and sling insults at you, its really because deep down inside, I hate myself. Please buy me some hair dye for my birthday.
Old Feb 14, 2010 | 10:09 AM
kawie636's Avatar
Hooligan
there sealed.
Originally Posted by _Will_
Mike was the obvious hooligan of the crowd, the sport bikes all looked like they were on warm up laps
I Bleed Green!!!!
GO VOLS!!!!!!!!!!
Old Feb 14, 2010 | 03:12 PM
stealthc9's Avatar
oh, i had no idea. I am running an interstate battery thats 4 years old, I just refilled it charged it and its been good to me
Morty,
Old Feb 14, 2010 | 03:14 PM
Clawhammer's Avatar
BELOW M3
My bike would randomly reset the cluster all the time. All my settings, trip, time, etc. It would happen while cranking. I also had to push start it every time the temp. dropped to the 50's or colder.
I put a new battery in and it hasn't done any of this since. I wish I would have done it two months sooner lol.
2008 R1 | 2004 ///M3
Old Feb 14, 2010 | 03:47 PM
J@meson's Avatar
Resident Ginger Kid...
I agree, they will not start with low voltage... And it may sound like its cranking normal but that little less than usual will make the differance. I thought I was chasing a electrical problem on my old 750 for a few weeks but turned out to be a semi weak battery. There cheap enough to change and get your moneys worth of time out of them.
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Feb 14, 2010 | 07:00 PM
stealthc9's Avatar
Morty,
