chain lube.....
Old Mar 7, 2007 | 12:46 PM
bigerb6969's Avatar
WHERE DA GOL' AT?!?!?!
Default chain lube.....
just got done washing my bike because im riding out to quaker tonight...and i decided to wipe off my chain also...got it pretty clean but i forgot that you are supposed to put some lube on afterwards...what kind of products can i use and where can i get them...can i use anykind of household product.....please let me know a.s.a.p....thanks
-eddie
Old Mar 7, 2007 | 12:50 PM
OrOr's Avatar
How fast officer?
Don't use wd-40 or any kind of penetrating oil/lube.
Old Mar 7, 2007 | 12:56 PM
bigerb6969's Avatar
my dad just found this stuff by DuPont called pure silicone lubricant-industrial grade...it says on the bottle that you can use it with o-rings&gaskets, chains&cables......do you think this would suffice?
Old Mar 7, 2007 | 01:54 PM
OrOr's Avatar
How fast officer?
It may or may not be the best lubricant for a chain, but it shouldn't do any damage. You should read the precautions to see if it destroys paint or chrome.
I used the Suzuki chain lube from a bike shop.
Old Mar 7, 2007 | 01:58 PM
DogBoneZX10's Avatar
Dragging Plastics
ANYTHING is better then nothing. But I recommend Maxima ChainWax in the gold can.
Do you really have to start a thread every time you go on a ride and see a guy with no helmet on?
Does it affect you that much that some random guy 1500 miles away went and paid his own money for a 1000?
Do we really have to fight over who uses the back brake or not?
Do you have to argue over stupid pointless shit on the Internet?
Old Mar 7, 2007 | 03:34 PM
1fstmaxima's Avatar
You use WD-40 to clean the chain, let it sit for about ten minutes. Then spray it with water. Let it drip dry then lube it with Chain wax or Chain lube. Let it set in for like an hour....
I have 14K miles on my bike now my chain looks like its new, the sprocket is also in great shape
WFO, had it off last week when I was replacing my tires. Normally clean and wax my chain around 500 - 800 miles or when it looks like it needs cleaning and chain lube. I do it after I ride so the chain is nice and warm, put it on a bike stand let it run in gear as I spray the WD 40 and let in spin a few times. Then I let it sit for about 10 minutes. Then spray it with my presure washer as its running in gear then when the chain looks good I let it sit for a few minutes. Then Spray it with Chain wax or PJ lube. When this is done the bike shifts great and smooth... I just did mine last night..
Old Mar 7, 2007 | 04:22 PM
Rales's Avatar
All Vacuum
I would never spray a chain with water after cleaning it with wd40. I simply use maxima or similar wax and just keep adding some every other fill up. My chains last about 20k miles on liter bikes.... I woudl also never spray a chain with wd40, however i do put it on a rag and wipe it onto the chain side plats to make it look pretty again
AIM: SolderedLego
Toys are fun, atleast they dont say NO.
Like to drink buy a drinking tee
http://www.tampaforums.com/forums/mi...s-more-289609/
Old Mar 7, 2007 | 05:18 PM
TurboKaw's Avatar
Why no WD-40?? That is the only lubricant I use on the chain for my dragbike.
-TK
If you can Turn you are not going Fast Enough!
Originally Posted by Raybo
I'm not a loser, I'm just incarcerated.
Originally Posted by Treysdad
Tell me about it. Sometimes i get this abrasion just under the head, liek a friction rash. All day it will feel like there is a Mexican midget in my boxers licking it with a cats tongue.
Old Mar 7, 2007 | 05:26 PM
Capt Insano's Avatar
I love WD-40...Anyone who has ever used it knows, it cleans like a mother...I use it alot on my bike, I actually just cleaned my chain very thoroughly with it. I typically wash the bike and dry it off as much as possible, then ill get down and clean any area where grease builds up with WD-40 including the chain. Then once it dry's I use Castrol Chain Wax...Just dont be an ass when putting the wax on, because you will get sling...I do this religously...
Old Mar 7, 2007 | 05:46 PM
OrOr's Avatar
How fast officer?
Cleaning with wd-40 and removing it afterwords is fine. Using it as a lube will destroy your o-rings and bearings. The reason it cleans greasy things so well is because it breaks down petroleum which is not only on your chain, but also in your seals and bearings.
