chain lube.....
Old Mar 7, 2007 | 08:15 PM
zx10ben's Avatar
I use "MOTOREX CHAIN CLEAN 611", it works better than any WD-40(as is made specifically for) grease drips off instantlly. Then apply "SILKOLENE Pro Chain" (to protect).
*Results are best when chain is warm. Wash bike, ride around the block, then clean chain.
Old Mar 8, 2007 | 04:51 AM
Slo Poke's Avatar
chicken sirloin
Originally Posted by OrOr
Cleaning with wd-40 and removing it afterwords is fine. Using it as a lube will destroy your o-rings and bearings. The reason it cleans greasy things so well is because it breaks down petroleum which is not only on your chain, but also in your seals and bearings.
i call bs on the whole WD-40 thing....i have discussed this at length on other forums and have found MANY riders with the same experience...I use only WD-40 for cleaning and lubricating....ive used it on every type of chain (x,e,exo,seal and unsealed) in dirt riding/racing and street riding....NEVER HAD A CHAIN PROBLEM....EVER......i have 14K miles on my ZX-10's stock chain (EK 525) and have used WD-40 only for lubing....rings are fine, chain wear is normal (actually slightly above average)...
man that shit is good fur almost anything....
Old Mar 8, 2007 | 04:52 AM
TNathe's Avatar
I'm willing to bet the chain TurboKaw uses probably doesn't have O-rings. Non-O-ring chains are much lighter and cheaper, however, they don't last nearly as long.
Old Mar 8, 2007 | 05:04 AM
MikeB's Avatar
eddie i have 2 can of chainwax you can have them, just let me know
-mike-
Old Mar 8, 2007 | 08:25 AM
bigerb6969's Avatar
WHERE DA GOL' AT?!?!?!
thanks for all your input guys....mike that would be awesome ill give you a call sometime so i can pick it up
Old Mar 8, 2007 | 09:38 AM
MikeB's Avatar
just let me know man
-mike-
Old Mar 8, 2007 | 02:34 PM
  #17 (permalink)
TurboKaw's Avatar
you are correct. But I still wanted to hear the "myths" on why not to use it. I have soaked all types of o-rings in WD-40 and never saw it break down. Guess it is time for an experiment, gonna spray some in a cup and dump in some o-rings and see what happens. Gotta beleive if the o-ring in the chain can not handle WD-40 it cannot handle the heat from being run at 160 mph on a lot of bikes.......
-TK
If you can Turn you are not going Fast Enough!
Originally Posted by Raybo
I'm not a loser, I'm just incarcerated.
Originally Posted by Treysdad
Tell me about it. Sometimes i get this abrasion just under the head, liek a friction rash. All day it will feel like there is a Mexican midget in my boxers licking it with a cats tongue.
Old Mar 8, 2007 | 03:05 PM
  #18 (permalink)
Slo Poke's Avatar
chicken sirloin
it might break it down over a few years or so....
Old Mar 8, 2007 | 04:05 PM
  #19 (permalink)
Dudeman's Avatar
stuntlife.com
Originally Posted by DogBoneR1
ANYTHING is better then nothing. But I recommend Maxima ChainWax in the gold can.
+1!
Old Mar 9, 2007 | 05:16 AM
  #20 (permalink)
TNathe's Avatar
and if someone's chain lasts a few years then they need to sell the bike and get a hover-round or something along those lines
