i am stuck now
Old Mar 3, 2007 | 06:12 PM
wolfey971's Avatar
Originally Posted by sl2racer
no the fuel is good. i never turn the fuel petcock off.
can someone better explain this hold the throttle open idea and why it would work?
basically what you are doing is airing the carbs out, when you choke a bike you cut off air to the carbs and dump straight fuel into the engine which means you flood it, if done too much, it will put too much fuel in the engine and will cause the plugs to become saturatied with fuel and foul out. holding the throttle open lets air into the engine to help evaperate the fuel.
when you flood a biek too much you will have a strong odor of gas when starting/ turning the engine over
Originally Posted by WSideShow
I hate the Florida Gators ughhhhh.
'04 GSXR 750
I'm so far behind, I think I'm first
need tires (take offs)? PM me
need a deal on a track day? PM me
disclaimer: I sell used tires (take-offs), these tires have been used at Jennings, Homestead, etc. (road courses for those that dont know) therefor these tires are more used up on the sides than in the middle,
Old Mar 3, 2007 | 07:47 PM
TurboKaw's Avatar
If the bike is flooded, turn off the choke, turn the throttle wide open and try and start the bike with the throttle wide open. Standard flooded start routine for carbed engine.
Did you at any time when you were messing with it take off spark plug wires?
-TK
If you can Turn you are not going Fast Enough!
Originally Posted by Raybo
I'm not a loser, I'm just incarcerated.
Originally Posted by Treysdad
Tell me about it. Sometimes i get this abrasion just under the head, liek a friction rash. All day it will feel like there is a Mexican midget in my boxers licking it with a cats tongue.
Old Mar 4, 2007 | 08:37 AM
sl2racer's Avatar
no i never touched the spark plug wires.
and now that holding the throttlw makes sence. i kinda thought you were messing with me about the thottle being open.
Old Mar 4, 2007 | 09:02 AM
FC3Cturbo's Avatar
eats babies
DO NOT use the choke when you are attempting to start it from a flood. It will just make it worse.
Old Mar 4, 2007 | 03:50 PM
sl2racer's Avatar
okay. took the plugs out and cleaned them up re gaped them. drained the carb bowls. drained the fuel pump and lines and drained the tank. all old gas gone and now clean plugs and dry cylinders and new gas. do you think the bitch would start nope. i even rewired in the old start stop switch and everything else to make sure that the new one was not the problem. still didn't start.
any new ideas?
Old Mar 4, 2007 | 09:32 PM
wolfey971's Avatar
by chance hae you checked your blinker fluid, flux capacitor
I know my bike wasnt acting right and all it was was the blinker fluid, topped her off, and gave the flux capacitor a few good wacks with a screw driver and she purred like a kitten
'04 GSXR 750
Old Mar 4, 2007 | 10:54 PM
  #17 (permalink)
sl2racer's Avatar
thanks. any real tries?
Old Mar 5, 2007 | 08:29 AM
  #18 (permalink)
sl2racer's Avatar
just went and got some starter fluid and still nothing. i also ordered some coils and i will try those too.
Old Mar 5, 2007 | 12:44 PM
  #19 (permalink)
sl2racer's Avatar
come on where are the bike tech guys. help a brother out.
Old Mar 5, 2007 | 12:59 PM
  #20 (permalink)
???'s Avatar
Capt."Howling Mad"Murdock
if you have spark and fuel, but it still doesn't even try to start.
I'd say its time for a can of gas and a match....
