electrical problems
Old Oct 5, 2006 | 04:50 PM
sl2racer's Avatar
checked the fuses yet? kinda sounds like you have a bad ground on your tail lights. not sure if the tail lights and the head light would have anything to do with each other thought
sl2racer's Avatar
is the left headlight always on? is it dim at all?
Old Oct 5, 2006 | 04:51 PM
wsideshow's Avatar
REACH AROUND EXPERT
fuses look good i checked the bike over and didnt notice anything outa place
left headlight works fine reg/brights
Old Oct 5, 2006 | 04:52 PM
sl2racer's Avatar
ahhhh wonder if your high/low beam switch is bad.
Old Oct 5, 2006 | 04:53 PM
wsideshow's Avatar
REACH AROUND EXPERT
but would that make 1 light work good and the other not?
Old Oct 5, 2006 | 04:55 PM
sl2racer's Avatar
does your horn work?
if your switch broke in the low beam setting it wouldn't be switching back and forth from low to high. when you put the switch on high beam does the blue light on the gauge cluster turn on?
Old Oct 5, 2006 | 05:02 PM
  #17 (permalink)
wsideshow's Avatar
REACH AROUND EXPERT
yes the blue light on the cluster does work .
horn doesnt work
Old Oct 5, 2006 | 05:06 PM
  #18 (permalink)
sl2racer's Avatar
hmmmm looking at the wiring diagram for your bike it appears the head light/switch/horn/tailight/ rear turn signals are all kinda linked.
are your front signal working fine?
Old Oct 5, 2006 | 05:07 PM
  #19 (permalink)
sl2racer's Avatar
have you ridin the bike around yet?
Old Oct 5, 2006 | 05:12 PM
  #20 (permalink)
iridenissan's Avatar
Check for current(amperage) and please break into the circuit, don't blow any fuses.....
