Triumph daytona 675
Old Jul 20, 2006 | 01:52 PM
  #21 (permalink)
Rotary7's Avatar
Get Down-Or-Stay Down
Originally Posted by mustangman70
Maybe its quicker through the twisties?
then that would be on the rider right?
Do you want to be tazed?
Old Jul 20, 2006 | 01:53 PM
  #22 (permalink)
Rotary7's Avatar
btw the test that were done,we not on "twisties"
Old Jul 20, 2006 | 01:58 PM
  #23 (permalink)
Colonel Mustard's Avatar
They call me Cooter..
way to piss on someones parade cool guy
Captain Morgan: When you die and go to heaven,you'll talk to God. THIS will be the stuff you'll smell on his breath.
Old Jul 20, 2006 | 02:02 PM
  #24 (permalink)
mustangman70's Avatar
carb cowboy
lol i know right...looks like someone has a case of the "mondays"
When i stated twisties i was refering to a TRACK with turns ....
by the way....in ???'s post.....he said the triumph WAS slower then the kawi 10R.....but came close in second
Ben-
Old Jul 20, 2006 | 02:16 PM
  #25 (permalink)
CodenameAcura's Avatar
Slow Is Good
Right beating all the other 1000cc bikes except the kawi!
-13 Suburu Impreza WRX
-10 Honda CBR1000RR (for sale PM me)
-07 Nissan Frontier CC (sold)
-99 JDM ITR DB8 (4dr whore) sold
-98 Acura Integra GS (Go Slow) sold
-04 Ford Ranger Ext Cab Step side (traded)
-03 Kawasaki KFX400 (sold)
-05 Kawasaki KFX400 (sold)
-02 GSXR 750 (sold)
-04 Triumph Daytona 600 (sold)
Old Jul 20, 2006 | 02:17 PM
  #26 (permalink)
???'s Avatar
Capt."Howling Mad"Murdock
Originally Posted by Rotary7
ummm.. where did you get this?
Out of the Truimph and the 4 Jap bikes,,
it actually has a slower 1/4 time.
less HP than the Kawi
slower 0-60 than the Kawi
5MPH slower top speed than the Kawi
but is the fastest?
in a 1/4 mile maybe but the 636 came in like 4th... (don't have the test in front of me)
check it out... i have read a lot of test but i like how the master bike test is run.
pick up this month's cycle world and read about it. i first saw some posts about it a few months back on the zx10 boards because the 06 came in 2nd this year and everyone was all pissed. so i started looking around and i really like the format of this test over all the others I've seen.
the 636 will hopfuly step up next year when the new bike comes out.
Old Jul 20, 2006 | 02:34 PM
  #27 (permalink)
???'s Avatar
well is this test only 3 bikes make the final.(the winner of each class) one for the 600s one for the 1000s and one for the middle which was the 1000cc twins and the gixxer 750.
the 675 came in 3rd overall in the final but really close to the times 10r was running(which was the fastest 1000 4cyc overall), the 10 came in 2nd to the aprilla(sp) that won the whole test.
all in all its a good read because they also start with about 20 riders and only the ones that run the best times get to move on to run the final 3 bikes to find out what the master bike of that year is.
it looks like a badass test with factory techs there to set up each bike to the track and riders.... its not you normal mag shoot out crap where whatever bike they like wins.... this test is on lap times.
Old Jul 20, 2006 | 02:36 PM
  #28 (permalink)
Rotary7's Avatar
I actually have the cycle world 2006 july magazine infront of me.
When I went to Boarders to buy it,there was 3 other magazines that did a 600 shoot out (im sure its the same testors)
The 675 was not considered the fastest.
0-60 3.2 sec
1/4 10.76 @129.31
HP 106.99 @12500 rpm
tq 47.49 ft lbs
top speed 155 mph
ZX6R
0-60 3.0
1/4 10.58 @132.36
hp 109.43 bhp @ 13210 rpm
tq 46.46 ft lbs
top speed 160
Heres the ups they said on the ZX6R that I like.
Killer torque/great top end power
drag racers delight
The 675 won the best "all around bike"
The 636 came in second (I dont see 4th place)
And almost won in 05 but it had "stability issues on the track.No symptoms this time though"
Old Jul 20, 2006 | 02:43 PM
  #29 (permalink)
Rotary7's Avatar
im known for that,havent you noticed?
Old Jul 20, 2006 | 02:44 PM
  #30 (permalink)
carb cowboy
Just some random specs from triumph
Engine
Type Liquid-cooled, DOHC, in-line 3-cylinder
Capacity 675cc
Bore/Stroke 74.0 x 52.3mm
Compression Ratio 12.65:1
Fuel System Multipoint sequential electronic fuel injection with forced air induction
Ignition Digital - inductive type - via electronic engine management system
Transmission
Primary Drive Gear
Final Drive
O ring chain
Clutch Wet, multi-plate
Gearbox 6-speed, close ratio
Cycle Parts
Frame Aluminum beam twin spar
Swingarm Braced, twin-sided, aluminum alloy with adjustable pivot position Front Wheel Alloy 5-spoke, 17 x 3.5in
Rear Wheel Alloy 5-spoke, 17 x 5.5in
Front Tyre 120/70 ZR 17
Rear Tyre 180/55 ZR 17
Front Suspension 41mm USD forks with adjustable preload, rebound and compression damping
Rear Suspension Monoshock with piggy back reservoir adjustable for preload, rebound and compression damping
Front Brakes Twin 308mm floating discs, 4 piston radial calipers with radial master cylinder
Rear Brakes Single 220mm disc, single piston caliper
Dimensions
Length 2010mm (79.1in)
Width (Handlebars) 673mm (26.5in)
Height 1109mm (43.7in)
Seat Height 825mm (32.5in)
Wheelbase 1392mm (54.8in)
Rake/Trail 23.5º/86.8mm
Fuel Tank Capacity 17.4 liters (4.6 gal US)
Performance
Maximum Power (123bhp) at 12,500 rpm
Maximum Torque (53ft.lbf) at 11,750 rpm
Colours
Scorched Yellow, Tornado Red, Graphite
Ben-
