Do 2004 forks fit on a 2005 zx636?
Old Aug 12, 2005 | 01:36 PM
rx7mpguy84's Avatar
Jimmy Korea
Default Do 2004 forks fit on a 2005 zx636?
As its titled, Will it work? I dont want to have to spend $1400 for new fork assembly.
Old Aug 12, 2005 | 04:50 PM
tampamax's Avatar
It should but to be sure go find the factory specs on the internet that will tell you if the are the same. If i'm not mistaken i believe they are 43mm fork tubes. You could also call a dealer and find out the part numbers for the 2 years. If the numbers are the same then they parts are the same. However, keep in mind that even though they don't have the same part number does not necessarily exclude them from working on a different model they were not intended for. And don't just take the shmuck at the parts counters word for it. Make sure they actually cross reference the part numbers. Parts guys think they know everything, but reality says otherwise.
If you need help putting you bike together for cheap then let me know. I can help out. You also would get a great head start on your rebuild if you would call mrcycles and get prices from Brad. Next stop is ebay....shouldn't be very expensive for a complete front end. You moght want to take some measurments to figure out just what it is you really need for the bike.
You don't like it? So sue me. Don't take me seriously though.
