BMWCCA auto X Oct 22
Soon enough.
When I'm sure another 30mm of rubber will fit under the front fenders.
I bet I won't even need to look out of the side windows to see where I'm going.
BTW nice runs, as usual.
Drew Scoda
'87 Mustang
Drew Scoda
'87 Mustang
I ran a 53.635 and was very happy to pull that off with my pig of a car -- I was "only" like a second off from some of my e36 M3 friends.
That was the most fun I'd had at an autocross yet (it was only my third), except for that last 90 degree left near the end... my car HATED that.
I noticed you had a rather unique approach to it. You brake as you entered it, accelerated pretty hard, then braked again as you made the left. I am thinking the second brake was to shift the weight of the car forward to get more traction to the front tires? Really seems like you're getting the most out of the car, I told my friends there you were going to pull the best time
I meant to post this the other day, but with Brian's vid I look like I am driving a shopping cart with a wiggly wheel.
330 SMG Fastest run 10-22-6 - Google Video
Sorry for the pixelation...I tested the mount on a smoother surface...will be adding some insulation.
I want to lend Drew my camera...I need to see him going through the slalom!
The part the impresses me the most about my run, and probably made the biggest difference in my times, was making that left/right so smooth and fast. It took a lot of steering input to get through there, and it was not easy.
I imagine Andrew must do the same thing through the entire course.
330SMG- A few things I noticed about your run; you are turning too late and too much and you went through the turn around too wide. Turning earlier and turning less will allow you to carry more speed. Keeping a tighter line will allow to cover a shorter distance. The less distance you travel, the faster you will be.
You need to grab ahold of that line between speed and chaos, and you need to wrestle it to the ground like a demon cobra.-Talladega Nights
My 53.635 run
Streaming
Download
Comments welcome. I understeered a bit too much at the turnaround and could have taken that smoother, and could have been probably faster in the initial few gates. This run was after hitting cones twice in a row, so I slowed it down a little and didnt hit any.
Streaming
Download
It looked like you turned a little late once or twice, and you took the slalom on the wrong side entering the turnaround. A little more air in the rear tires would help with the understeer.
Hopefully, I am not insulting anyone by trying to offer advice.
I know I have upset someone by doing that recently.
I actually preferred taking the slalom to the left as I ended up with fewer turns and the exit seemed easier to make, after watching people take it on the right repeatedly I felt the left was best for me. If I had more time I'd have tried it the other way around.
Thanks for checking the video and the advice =)
330SMG- A few things I noticed about your run; you are turning too late and too much and you went through the turn around too wide. Turning earlier and turning less will allow you to carry more speed. Keeping a tighter line will allow to cover a shorter distance. The less distance you travel, the faster you will be.[/quote]
On all of the turns or just the turn around?
I am usually more patient...but it was hard to judge the turn around because of the slalom right before it. I also was late on the l box at the end, but that was out of fear of catching my right rear on the last cone. I was rushing through the course because I knew I was going to lose time to Russ in the box.
And djben...definetly take air out of the back. I had 48 hot upfront and 36 hot in the back and the car was very neutral.
