pioneer head unit problem
Old Nov 13, 2009 | 10:10 AM
  #21 (permalink)
NT_Hardcore's Avatar
bassheadsent.net
new tampa, cross creek.
http://www.bassheadsent.net/
Old Nov 13, 2009 | 10:22 AM
  #22 (permalink)
luke81's Avatar
The amp to sub connection has nothing to do with the HU's internal amplifier, but it will damage your sub amp if it shorts. without a meter it's hard to define any electrical problem, but try this if you can: Take a speaker that you know is good, and is 4 ohms. IE any coaxial speaker will work. Unhook all of the HU's speaker leads from your car and one at a time hook it to the speaker. If it works like that you're in luck, the unit is only protected. If not, it's possibly busted.
I lived out in Cross Creek when i first moved to FL 4 years ago, nice area!
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
  #23 (permalink)
Invader_Zim's Avatar
Typical TR Asshole
^^dunno where that is at ^ and i will try that now brb
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Nov 13, 2009 | 10:24 AM
  #24 (permalink)
bassheadsent.net
like uh bruce b downs and i75
1.This forum requires that you wait 45 seconds between posts. Please try again in 9 seconds.
Old Nov 13, 2009 | 10:37 AM
  #25 (permalink)
Typical TR Asshole
so i tried what you said and got no sound from anything so i am thinking that the head unit is done. but im still wondering what is causing the issue if it isnt that wire from the amp to the sub then what? im stumped
Old Nov 13, 2009 | 10:43 AM
  #26 (permalink)
bassheadsent.net
ur shure the speaker u tested with is a good speaker? i blew some 6.5's but the read 3ohms (shuld read 4ohms) instead of 4ohms. this blew the amp i had em on but if they are hooked up to a 2ohm stable amp they play fine.
Old Nov 13, 2009 | 10:53 AM
  #27 (permalink)
Typical TR Asshole
k lemme check again i need a laptop
Old Nov 13, 2009 | 10:55 AM
  #28 (permalink)
bassheadsent.net
u have to disconnect all the speakers being ran by the HU when u test it btw. if u wanna shared_pm me ill give u my num and try and explain it over the fone lol. this is how boring my day job is
Old Nov 13, 2009 | 10:58 AM
  #29 (permalink)
Typical TR Asshole
lol @ boring day job. well i looked at the speakers and they are 4 ohm (they had 4 and the little ohm sign next to them) i also had an extra harness for the head unit that i hooked up and tried the one speaker at a time thing and it still dont wanna work
Old Nov 13, 2009 | 11:00 AM
  #30 (permalink)
bassheadsent.net
but if the speaker isnt reading 4ohms (could be bad or worn out) the unit will still go protect. with out a multi meter you will not know if the speaker is "good"
