system help
Old May 13, 2009 | 03:20 PM
Ricksta's Avatar
I FUCK LIKE A PORNSTAR
Default system help
i plan on picking up these tens
Kenwood KFC-W2511 (kfcw2511) 10" Component Subwoofers Car Subwoofers Car Audio and Video - Sonic Electronix
and my question is, will this amp here be enough to run these speakers and still pack an awesome punch? if not does anyone have any recommendations? my friend tells me he wont install it if i get non name brand lol
Kenwood KAC-7204 (kac7204) 2-Channel Amps Car Amplifiers Car Audio and Video - Sonic Electronix
sig pic removed
Originally Posted by pnkpnthr2133
that shit looks jagged, she's gotta open her mouth at some point so ricky can stick his dick in it...i don't want him to get hurt...
Old May 13, 2009 | 04:26 PM
kpr10is's Avatar
Maximaniac
Going by ratings, you are only going to get 170 watts per sub with those subs, running the amp in stereo at 4 ohms. Would it do the job okay? Probably, because those entry level subs aren't too power hungry, but you would get a little more out of them with a mono amp at 2 ohms, probably 500ish watts RMS.
Old May 13, 2009 | 05:00 PM
Ricksta's Avatar
i originally wanted these rockfords
Rockford Fosgate Punch P2D410 10" Component Subwoofers Car Subwoofers Car Audio and Video - Sonic Electronix
but my friend said that i would have issues running two of these off one amp because it has dual voice coils?
sig pic removed
Old May 13, 2009 | 05:48 PM
kpr10is's Avatar
Maximaniac
There is your problem. It seems like everyone has a 'friend' that feeds them bullshit because the friend doesn't know what they're doing, so kudos to you for posting to get other opinions. And from the sounds of it, I wouldn't listen to a whole lot that the said friend has to say.
The dual voice coil subs would actually work better off of the amp you linked. Issues do not arise by running dual voice coil subs from one amp, issues arise when the voice coils do not match the final impedance the amp needs. With those dual voice coil subs, you would have a final load at the amp of either 2 ohms stereo or 4 ohms bridged, either way getting you more power out of your amp than the single voice coil 4 ohm subs.
To put it simply, with the first subs you linked you would get 170 watts rms x2 from the amp when the subs say they handle 300. With those dual voice coil RF subs, you would get 250 watts rms x2 from the amp when the subs say they can handle 250.
Old May 13, 2009 | 06:00 PM
ProvenPower's Avatar
Well said Kpr10is.
If you are set on that amp then go with the Rockfords. If you go with the Kenwoods you wont be using the amp to it's full potential.
WWW.PROVENPOWERTAMPA.COM
813-988-3966
ECU Socketing, Custom wiring Harnesses, Stereo, Alarms, Navigation, Electrical Troubleshooting, and More!!!
Old May 13, 2009 | 07:43 PM
Ricksta's Avatar
wow this is pretty badass. im still kind of confused on how its getting me more power using dual.
i was eye balling this mono amp. this would be my first setup so i am not sure of the difference between 2 channel and mono but this one doesnt seem to have that bad of a price
JVC KSAX5700 [KSAX5700] - $164.99 : AVD - Car Stereos, Car Speakers, Home Theater Systems, Navigation, In-Dash DVD Players, Televisions
so if i got this mono amp i would exceed peak power and risk blowing the subs?
sig pic removed
Old May 13, 2009 | 08:15 PM
kpr10is's Avatar
Maximaniac
For your purposes, it will mainly depend on which subs you go with because you want to match up the impedance of the sub(s) with whatever a corresponding amp can handle. If you have two single 4 ohm subs on a mono amp, you will have a 2 ohm load at the amp; if you have those same subs on a 2 channel amp, you will have two individual 4 ohm loads (one sub per channel). If my earlier posts are confusing, then don't worry about how to wire dual voice coil yet other than the bottom line that your final ohm load needs to match that of your amp, be it 2 channel or mono.
I understand that you filtered the results on that site by selecting mono amps, but that is still a two channel. Even the ratings they list say "Continuous power (RMS) of 200W X 2." One of the million reasons you can't trust these no-name internet retailers, because I guarantee they have plenty of people buy it thinking it is a "900w" mono as they state and are stuck with an amp that they can't return and that won't work with their subs. Shops are around to help you and if they're not helpful then find a new shop. It's sad to see incompetence killing the industry as much as it is--many of those people who get screwed by internet retailers give up on car electronics because of one or two bad experiences that a little knowledgeable help and a proper installation would have easily avoided.
Old May 14, 2009 | 01:35 AM
Ricksta's Avatar
thank you for the help! i'll just go with the kenwood im sure i'll be satisfied
sig pic removed
Old May 14, 2009 | 02:25 PM
Ricksta's Avatar
well this is what i went ahead and ordered. way more than what i planned on spending but oh well!
so i have 2 ten inch Rockford Fosgate Punch P2's
10" Dual 4 ohms Punch Stage 2 Subwoofer
Power Handling:
Peak: 500 watts
RMS: 250 watts
Impedance: 4 ohms
Parabolic Triangular Geometry cone support system for reduced piston flex
30oz. double-stacked magnet assembly increases excursion capability
Compliant linear spider eliminates need for break-in period
2" anodized aluminum voice coil former stays up to 100° cooler
Reversible concealing ring hides mounting screws
Large roll surround allows for 20% greater linear excursion than standard surrounds
Stitched-in tinsel leads handle tons of power
Custom 10-AWG nickel plated push terminals
Venturi-effect cooling design
Frequency Response: 30-250 Hz
Sensitivity: 84 dB
1-year Sonic Electronix warranty
2 pairs of these pioneer 6x8's.
6" x 8" A Series Car Speakers
Power Handling:
Peak: 560 watts per pair / 280 watts each
RMS: 100 watts per pair / 50 watts each
Composite IMPP with interlaced aramid fiber cone woofer
Foam rubber coated cloth surround
1/2" Light weight balanced dome with magnetic fluid midrange
3/8" Soft dome tweeter
Glass-imide voice coil bobbin
Nomex damper
Heat resistant Polyester Imide coat voice coil
4 ohms impedance
Top-mount depth: 2-1/2"
and this nice kenwood 2 channel amp.
2-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 170 watts x 2 chan.
2 ohms: 250 watts x 2 chan.
Bridged, 4 ohms: 500 watts x 1 chan.
Max power output: 500 watts x 2 chan.
MOSFET power supply
LED power indicator
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Bridgeable operation
Speaker-level inputs with signal sensing for automatic turn-on)
Preamp RCA outputs
Short circuit, DC offset, overload, and thermal protection circuitry
Aluminum die cast heat sink
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 5-50000 Hz
Dimensions: 13-3/4"L x 2-5/16"H x 9-3/8"D
8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
sig pic removed
Old May 14, 2009 | 02:28 PM
Ricksta's Avatar
here is the box im working with. its built pretty damn sturdy. but with these subs im not sure if i should drill holes because with these subs there is def going to be a whole lot of air but nowhere for it to go except out the front of my speaker and then im pissed! my friend tells me not to drill because then i will lose clarity and wont hear anything when im listening to rock (which i love). but i also listen to rap, techno, etc. so not sure what to do. i'll def sacrfice clairty if that means i dont blow my speakers.
sig pic removed
