system help
Old May 15, 2009 | 05:03 AM
luke81's Avatar
Whenj you say "drill holes" please explain. It sounds like you're considering drilling holes in the box, sort of like very poorly designed ports.....please dont do that.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old May 15, 2009 | 05:19 AM
NT_Hardcore's Avatar
bassheadsent.net
^^^+1
http://www.bassheadsent.net/
Old May 15, 2009 | 04:42 PM
Ricksta's Avatar
I FUCK LIKE A PORNSTAR
yea i looked into it. not a great idea. im going to see how i like this sealed box. i listen to a lot of rock so im not sure if ported will be the best idea.
sig pic removed
Originally Posted by pnkpnthr2133
that shit looks jagged, she's gotta open her mouth at some point so ricky can stick his dick in it...i don't want him to get hurt...
Old May 16, 2009 | 05:42 AM
luke81's Avatar
I'd stick with the sealed box for now. There is always a difference in the required volume for a ported box, so if they're working well in the sealed box it's going to end up too small to port it.
Luke
Audio Expert
727-573-2626
Old May 17, 2009 | 04:50 PM
Notladstyle's Avatar
King of Ricers
Originally Posted by Ricksta
here is the box im working with. its built pretty damn sturdy. but with these subs im not sure if i should drill holes because with these subs there is def going to be a whole lot of air but nowhere for it to go except out the front of my speaker and then im pissed! my friend tells me not to drill because then i will lose clarity and wont hear anything when im listening to rock (which i love). but i also listen to rap, techno, etc. so not sure what to do. i'll def sacrfice clairty if that means i dont blow my speakers.
holy shit you have got to be a troll.
notladstyle.blogspot.com
Old May 22, 2009 | 02:21 PM
Ricksta's Avatar
installed everything last nite. i have to say these are some pretty badass subs. kinda makes me want to go ported. installed the cap and no idle issues she runs fine and i have enough juice to run the setup, but still going to upgrade alternator wires.
when i listen to rock its great!
but when i listen to rap the base is so deep i can barely hear the music. i had to turn down the base to 5 out of 15 just so i can raise the volume to 23 so i could hear the music! is there a way to make the door speakers louder at a lower level on the volume? i have the trebble or whatever its called all the way up as it is.
sig pic removed
Old May 22, 2009 | 02:24 PM
  #17 (permalink)
Ricksta's Avatar
would it be better to run these subs bridged? would that give me more power? that would reduce it to 2 ohms right? is that bad for the subs?
sig pic removed
Old May 22, 2009 | 07:15 PM
  #18 (permalink)
Ricksta's Avatar
i got greedy today and wanted more power so i bridged it and blew a fuse. i dont understand that because those speakers can handle 250rms each. although my lights started to dim so i think maybe it shorted from not enough power?
sig pic removed
Old May 23, 2009 | 06:48 AM
  #19 (permalink)
luke81's Avatar
Hold on a second before you go blowing things up. You can't just drop the impedance on an amp because you want to. These subs you listed are Dual 4 ohm subs, so how did you wire the coils? Parallel or series? Did you go + to + or + to -? It's going to make a big difference. If you wire the subs in parallel (pos to pos) then you need to run the amp in stereo, which will still deliver the full 250 watts per sub the amp is capable of. Simply hook each sub up to one channel of the amp, and you're set. If you go bridging it when everything is wired in parallel you're trying to ask the amp to run a 1-ohm mono load, which it is not even close to capable of doing.
Now this is all different if your woofers are single coil. If you've got single 4-ohm subwoofers, you've got the wrong woofers for the application.
As for your door speakers, turn down the sub level to match it. You're not going to get them any louder without putting an amp on them.
Luke
Audio Expert
727-573-2626
Old May 23, 2009 | 02:36 PM
  #20 (permalink)
Ricksta's Avatar
ok makes sense. i have a lot to learn i guess lol. these are wired positive to positive. i had googled it and thats what it told me to do. not sure what would happen if it was opposite
so im already getting 250rms at 4 ohms even though the amp sais im getting 170?
sig pic removed
