box build
ill have to do that.. ill just have to fill the gap in cause i already rounded over the outside edge
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
i just remeberd i cant dubble the port wall cause the box fits to tight as it is
sub will be installed in the AM.. still got to cut out for the termanel so the wires not ran though the port and then get it coverd down the road
also box will be sub / port up its just sitting in there like that for storage cause we have no where to store it
done till carpet
You've got box building down, not try and make it LOOK nice.
.. and please tell me you arent hiding hte amp in the side panel
Yeah overall that's not a bad box. Your cut got a little wacky on the sub hole, but as long as the sub fits with no leaks it's fine. Now give it a nice covering job with some carpet and it'll be a solid job. You've even got room on and back to create a nice little amp rack and do something cool.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Luke
Audio Expert
727-573-2626
amps are on the back of the seats.. he wants the box to be easly removed just in case.. took it out to get a vid poped the fuse in less then a min.. had a 40 amp in there.. i put my 250 amp audiopipe ANL fuse on and going to go get a vid in a few.. cut looks weird cause i used a skillsaw to cut the stight lines and a jigsaw to do the corners
if your talking about the power wire and ish in there thats from when the amps where on the hatch..
