Installing aux input
Old Dec 16, 2008 | 12:31 PM
robofunc's Avatar
rocktastic
Default Installing aux input
I've got a 2000 Integra w/ the factory CD/Stereo. I want to install an aux input so I can plug in my iPod (or anything w/ a 1/8" jack).
I'm looking for pointers/warnings from anyone who's tried this before. I've searched this forum and Honda Tech, but I'm not seeing anything.
Has anyone here tried this? Is it possible/worth doing?
Thanks.
Old Dec 16, 2008 | 03:28 PM
jriggs's Avatar
is better than you™
does the car have a cd changer?
Old Dec 16, 2008 | 06:48 PM
robofunc's Avatar
rocktastic
nope, just the OEM single DIN cd/stereo.
Old Dec 16, 2008 | 06:52 PM
Ink's Avatar
Ink
Changes names a lot.
You know you can buy some head units that have an Ipod jack/Auxiliary input..their pretty cheap to. You can get one for like $100 or so
Old Dec 16, 2008 | 06:53 PM
jriggs's Avatar
is better than you™
boo, well that scratches the quick easy way to add an aux in, if there is a tape deck (sounds like nope) then you can take the head unit apart and solider onto the aux inputs via the deck.
other than that sounds like an fm modulator or new head unit is what your going to have to do
one of the shop guys will probably chime in with a "plug and play" if one is available.
Old Dec 17, 2008 | 03:55 AM
MCOR's Avatar
Attachment 113089
Attachment 113090
If you have the small blue plug on the back of the radio (or the port is empty on the radio but will accept it-most likely the case with what you have described), you could use a Peripheral plug-n-play harness and auxilary box similar to the ones above. It will allow full seamless stereo sound integration through the factory system. If you are mechanically inclined, you can do this project for under $100 in parts. We do lots of this type integration and it sounds tons better than FM Modulation (that is a last resort if no plug-n-play options are available).
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
Old Dec 17, 2008 | 07:20 AM
robofunc's Avatar
rocktastic
ink, I want to keep the factory unit--so many aftermarket ones are just ugly. I'm going for a discrete wire in the empty DIN slot just below the radio to keep everything factory-looking.
Mcor, thanks for the info. Looks like it's time to pull the radioand see what I'm working with.
