bad lead wire?
well i have an issue with my sub i was going to use in my install. havent used the sub in forever maybe 3 years or so and went to plug it in today to make sure it still works. the sub will play sometimes but if i press on the wire running across the spider it will play. or just touch the lead wire a little it plays. i called speaker exchange and they said its probably a bad lead wire but they might not be able to fix it. does anyone know what i can do myself to try and fix it. i am going to take it to them tomorrow hopefully so they can look at it. if not i guess im going shopping for a new sub. thanks. its an audiobahn AW1008X AudioBahn AW1008X Car Subwoofer Details and Product Specifications - Epinions.com
lead wire?
You mean a remote turn on signal? Wouldn't that be related to your amp? Does the amp have status lights? On/Protection LEDs?
the voice coil wire... right?? goes from the speaker terminal on the sub into the voice coil on it..
i have fixed a few on my Bostwick competition 15...
shoot me a pic of the sub.. I may be able to help you out...
These can be soldered may times at the terminal lead with lots of paste flux and really low level heat from the solder gun. Losts of patience also. If it is broke at the cone area, some can be fixed, some cannot. Cheap subs can be somewhat glued (I have seen it done sucessfully-although a little scary looking) but if you have nothing to loose (it's just an old Audiobahn) may as well experiment. It probably isn't worth having fixed if it will cost more than $50 (usually will) and they usually won't put a guarantee on it unless it is reconed. Just my experience though...
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
Now there's some logic!
