amp cuts in and out.
Old Apr 27, 2008 | 06:09 AM
Pshull727's Avatar
dude what it sounds like u dont have the amp wired right you said it was a older amp what ohm rating are ur subs and and what can the amp do alot of older amps cant run in 2 ohms and can check how many ohms your subs and putting out with a volt meter and it can also be a bad ground or the power wire is too small and cant get the wattage needed to run the amp.Just trying to help look in to these things.
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
Old Apr 29, 2008 | 12:35 PM
Boostin95Talon's Avatar
Try stepping down the "bass boost" or "gains" whichever your amp may have....could be that its clipping on ya?
Old Apr 29, 2008 | 03:00 PM
TBSpyder's Avatar
Any updates?
Old Apr 29, 2008 | 05:52 PM
IThaJokaI's Avatar
Hates cars...
Tried and made sure I had everything wired correctly. My other to smaller amps will power on fine, but this one just wont work. As for the gains, they are set all the way down anyway.
Old Apr 29, 2008 | 07:47 PM
nismokid's Avatar
The New Jessie James
Originally Posted by joebobclark
Protection lights? What ohm load are you running? Bridging the amp? Ohm load may be too low for this "older" amp...
+1 Ohm rate WILL effect the amp. I had the same problem with one of my older amps, turns out that the amp wasn't able to run at 1ohm, try switching it to 4ohms at the least. If the problem still occurs then its time for a new amp.
Old May 2, 2008 | 04:37 PM
Thatguysstuff's Avatar
Hey its that guy!!
^+1
