speaker question
will amplifing the car door speakers will make a huge difference? such as clarity? or more bump?....to me i think it is a waste of money on buying another seperate amp just to give the speakers 40-50watts while the h/u give out alittle power alone.
what you guys think?
Yes it does make a difference.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
big difference.
Yeah it makes a huge diffeence espicially if you have good speakers.
Pm me for your welding needs. I do most minor welding, tack welding, and some exhaust.
2000 v6 mustang 5 speed
shorty headers with cats, o/r h-pipe, 2.5 true duals with flowmasters, ported and polished maf, ported and polished tb, fenderwell cold air intake, short shifter, and zoom stage one clutch and assembly.
R.I.P Dustin...Forever a friend...Forever a brother.
Compare your '4x50' headunit to a 4x50 amp. First, the headunit is much smaller, and it has to have all the headunit stuff, as well.
Then, check the power. Best case, 200 watts takes about 14 amps (14.4 v, 100% efficient) while most headunit only have 5-10amp fuses
I'm not saying that headunit manufacturers lie, but...
Toby
Toby
That's what you're CLEARLY saying Toby
On top of the fact that you don't have to worry about the low power output of those internal amps, you have a lot less noise and clearer sound (as long as you have good wires that are set up PROPERLY).
Take advantage of and fine tune the crossovers built into most amps, thus allowing you to raise the volume even higher while protecting your speakers AND making them sound "better". (better being a subjective term)
.On top of the fact that you don't have to worry about the low power output of those internal amps, you have a lot less noise and clearer sound (as long as you have good wires that are set up PROPERLY).
Toby
Toby
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Now there's some logic!
