can you extend wires from ballast to bulb on hid
Old Aug 18, 2007 | 09:46 AM
cantcatchmeboy's Avatar
owns a $10,000 unicycle!
Default can you extend wires from ballast to bulb on hid
will it hurt anything?
**new sig coming soon!**
Old Aug 18, 2007 | 01:33 PM
jriggs's Avatar
is better than you™
when i had retro fits on my gs i extended the wires so i could hide everything and everything worked with no problems for the month i had them (i'm pretty sure the guy that has them now has no problems) just try to match the gauge of the wire and make real solid connections, i also put heat shrink rap on mine to help water tight the cut connections.
Old Aug 18, 2007 | 04:17 PM
P057's Avatar
isuck
Pretty much what jriggs said, just make sure to make the wire SOLID, use a high quality plug or better yet, solder it nicely. Then use heat shrink tubing rather than electrical tape, always..
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Aug 18, 2007 | 05:46 PM
Notladstyle's Avatar
King of Ricers
+1 ^ solder and heatshrink or liquid tape for watertightness.
notladstyle.blogspot.com
Old Aug 19, 2007 | 01:09 AM
SmokinS13SR20's Avatar
That ginger...
I'm not sure where it was, maybe TV, but I saw a high quality shop using electrical tape, I was like..."No."
Old Aug 19, 2007 | 04:34 AM
TJElite's Avatar
The wires between the bulbs and the ballasts are high voltage. So, I don't think you can just use regular 300 or 600 v wire. Well, you probably could, but it wouldn't be the best idea. On all the HID's I've ever worked with, that 'wire' is a couple of HV wires in a sleeve.
Jriggs...you extended between the bulbs and the ballasts with regular wire?
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Aug 19, 2007 | 04:53 AM
P057's Avatar
isuck
It mainly depends on the application and the location of where you're using it.
In the engine bay and on a wire that would require an insane amount of voltage going through it would be something I don't want to cheap out on.
Old Aug 19, 2007 | 07:40 AM
King of Ricers
the current that runs though a ballast is miniscule. by ohms law, a 300v 10a line would be like 300,000v 500ma run which would be good enough for the job. There are at least three conductors, ground, high, and low.
Old Aug 19, 2007 | 01:25 PM
TJElite's Avatar
You're kidding, right? I'm not talking about the wattage carried by the wire, I'm talking about the dielectric strength of the insulation. Why do you think they use 5kv cable for neons?
Also, it is extremely rare to find HID high beams. They take too long to heat up. Since most people only use their high beams for short periods of time, HIDs wouldn't work very well. Even many factory HID installs use regular filament bulbs for high beam.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Aug 19, 2007 | 02:09 PM
King of Ricers
I am not talking about high and low beam. Some ballasts use two igniters and a common wire to ignite the gas. You are right though, the wire would need a very large layer of insulation but the conductor itself doesn't need to be more than 18ga. look at the conductor in the picture
