can you extend wires from ballast to bulb on hid
Old Aug 19, 2007 | 02:35 PM
P057's Avatar
isuck
Originally Posted by TJElite
Even many factory HID installs use regular filament bulbs for high beam.
Toby
Yep, mine do.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Aug 19, 2007 | 02:59 PM
jriggs's Avatar
is better than you™
Jriggs...you extended between the bulbs and the ballasts with regular wire?
yes from bulbs to ballasts. i don't think its 'regular' wire presay, i picked up the wire from dads shop (mark III) the guys there matched it 'exactly' to what was already there, or at least thats what they told me, it could have been some cheap shit and i got lucky and didn't melt the world under my hood lol.
-james
Old Aug 19, 2007 | 03:48 PM
TJElite's Avatar
Originally Posted by NoTLaDStyle
I am not talking about high and low beam. Some ballasts use two igniters and a common wire to ignite the gas. You are right though, the wire would need a very large layer of insulation but the conductor itself doesn't need to be more than 18ga. look at the conductor in the picture
You said high and low, and I figured you meant beams. No matter.
The conductor probably doesn't need to be more than 28 gauge, really...its the insulation that matters. That's why I said that normal 300v (most automotive wire is 300v class at best) or 600v wire would be a bad idea.
I remember when neon under cars first hit the scene, back in about 92. Guys were just using regular glass tubes and transformers, like you would in a sign. They were also using regular automotive power and (gasp) speaker wire. Lots of cars burned down.
My guess (hope) is that Jriggs got some higer voltage cable. Back to the original question. If you get the right wire, and use the right connections (heat shrink won't do it, unless you use lots and lots...you really need an air gap.) you can extend the wires between the bulbs and ballasts, but if you can avoid it, I would.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Aug 19, 2007 | 05:14 PM
Notladstyle's Avatar
King of Ricers
i was thinking high and low peaks of an ac wave. im not up to par on the principles behind high voltage equipment. I ran out of $$$ for classes so i have to wait another semester =(
notladstyle.blogspot.com
