Is there something to prevent rattle from the trunk
Old Aug 12, 2007 | 05:48 PM
88RedRex's Avatar
Protected Taurus .45/.410
Dyna Mat
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
Old Aug 12, 2007 | 06:21 PM
Notladstyle's Avatar
King of Ricers
Face your subs into the passenger compartment, no trunk rattles.
notladstyle.blogspot.com
Old Aug 12, 2007 | 06:46 PM
ShroomDaddy's Avatar
Soldier
HushMat is what I use and the only rattle comes where it isn't matted
If it feels good, then it isn't gay.
Old Aug 13, 2007 | 08:35 AM
integralsgreen's Avatar
i dont know if a pro shop would do that. it just a cheap easy diy fix. but i dont know. hey toby have you ever used expanding foam in places you cant get dynamat into?
Old Aug 13, 2007 | 04:55 PM
King of Ricers
expanding foam will not solve the problem because bass isn't just pushing on the panel all the time. Regardless of how much foam you put into the middle of the panels, the subs produce negative air pressure which pulls the panels outwards as well. All you are doing is adding something else for the sheet metal to smack into.
Dynamat works by dampening incoming vibration from other panels, and weighing down the panel itself so that it takes much more force to move it. Anything lighter is useless. Thats half the reason it takes twice as much peel n seal of equivalent because they are lighter than dynamat.
Old Aug 13, 2007 | 05:10 PM
metal on metal vibration= loud clattering noise. metal on foam = no clattering. when you get a chance pop your hood and look between petween the outer sheet metal and the inner skeliton. you will see quarter size daps of foam from the factory......why? ....to prevent clattering vibration. btw you cant physically get dynamat in some places such as between a peices of sheet metal spotwelded together(like between the skeliton and sheet metal of a hatch or inner structure parts. like i said its a cheap quick fix, dynamat isnt a fixall either
Old Aug 13, 2007 | 05:22 PM
  #17 (permalink)
P057's Avatar
isuck
I foamed up the inside of my trunk panels and it barely made a difference until I RAMmatted it.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Aug 13, 2007 | 05:59 PM
  #18 (permalink)
King of Ricers
The quarter sized applications are to dampen occasional vibration from other panels. Not to handle violent pressure waves from subwoofers. They also use something much softer than expanding foam(which is very brittle when dry)
A quarter sized portion is also a lot different than filling your trunk openings to the brim.
Old Aug 14, 2007 | 08:45 AM
  #19 (permalink)
nothing will stop violant vibration from a subwoofer. not even dynamat. shit i can sit on my trunk and it will still vibrate. once again...cheap fix. and you cant tell me it dosnt work. its ben tried and tru. probly not good for every aplication but it worked for me. im not sayin everyone go out and do this instead of dynamat. of corse it no replacement for dnamat but its another option to get the rattels that dynamat didnt because of accessibility issues. so quit bein such a nay-sayer dalton
