question
Old Jul 7, 2007 | 02:01 AM
1stGen7's Avatar
layin frame for life
Default question
ok well im tired of replaceing fuse's in the suburban.. what would make the fuse and fuse holder melt? this is the 2nd fuse and holder that has melted in this truck... should i run another run of 4 ga power wire will that stop it by helping it get mre power to the amps?
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
Old Jul 7, 2007 | 04:45 AM
P057's Avatar
isuck
get it off the engine?
Old Jul 7, 2007 | 05:16 AM
1stGen7's Avatar
its screwed to a peice of wood next to the battery
Old Jul 7, 2007 | 07:13 AM
Notladstyle's Avatar
King of Ricers
skipp the fuse box altogether.
notladstyle.blogspot.com
Old Jul 7, 2007 | 03:40 PM
GradeA_TireFryer's Avatar
All American, rice eater!
check grounds!!!!!!!!!!!!!!!!!!! - use quality products, amp is pulling to much amps, rewire lower ohm load!, i can keep going but that is basic installer stuff - pay someone who knows what they are doing!!!!!
Old Jul 7, 2007 | 04:12 PM
d.a_user's Avatar
...ouch
Old Jul 7, 2007 | 05:38 PM
King of Ricers
if his grounds were bad, there would be less current flow. Now if theres a bad connection in the fuse block itself, that could lead to arcing which could melt the block.
If his amp is pulling too much current, he needs a higher ohm load.
Old Jul 7, 2007 | 05:47 PM
.Seth.'s Avatar
TR Balla Donor Supreme
I'd go w/ whatever Dalton says, he knows his shit
Old Jul 7, 2007 | 09:05 PM
the727kid's Avatar
You got the right size fuse, and it's not to small? Do you have any corroded or loose or poorly crimped connections?
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Jul 7, 2007 | 09:15 PM
1stGen7's Avatar
both where 100 amp fuse's that came with the power wire.. didnt have a problem in the skylark with them and we had 3 amps sony xplode 1000 sony xplode 1200 and dhd 1200 now there is only the sony xplode 1000 and the sony xplode 1200.. but there was 2 runs of 4 ga in the skylark.. the connections where crimped from the factory.. when her gets payed thursday hes going to go buy 2 round fuse's and holders and put them in i ran another run of 4 ga today
