need a little help
Old Mar 30, 2007 | 07:17 PM
SkwervE's Avatar
realer than most
Default need a little help
i've got everything hooked up and when i turn the volume up the sub will cut out like distorting the bass and then cut back on and then cut back off.. it only does it when i have the volume up though.. it's been years since i've fucked with any systems so i have no idea what it could be..
Old Mar 30, 2007 | 07:32 PM
P057's Avatar
isuck
Check if you have the gains set too high.
There are toooo many different factors. Mainly try that first, get them low as you can. if you can't hear anything having them that low its because the amp is too weak for the subs. Get a stronger amp.
also check grounds., make sure you have a SOLID ground connection and the ground is equal beefiness as power
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Mar 30, 2007 | 09:01 PM
joebobclark's Avatar
Your Moms New Boyfriend
Sounds like protection mode. What amp? What subs? How are you subs wired to the amp (series, parallel)? Sounds like the ohm load is dropping to low and sending the amp into protection.
Old Mar 30, 2007 | 09:48 PM
P057's Avatar
isuck
yeah its definitely protection mode, but given the fact that he says it only happens when he turns it up kinda rules out the Ohm load factor..... unless he had it at a ridiculously low ohmmage and the amp was overheating quickly (but wouldn't explain the volume = drop)
I'm feeling its his grounds.
Old Mar 31, 2007 | 06:19 AM
Notladstyle's Avatar
King of Ricers
low ohms will send it into protect if it pulls a lot of power.
notladstyle.blogspot.com
Old Mar 31, 2007 | 06:45 AM
the727kid's Avatar
x2, you can run a lot of amps at too low of an ohm load at low volume. More info would be helpful here though, VC Config of the sub, describe how it is wired. What size power and ground, what kind of amp.
But you talk of distorting bass, I would say set your gains properly. JL Audio's website has a good tutorial on how to set the gains.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Mar 31, 2007 | 06:52 AM
P057's Avatar
isuck
you can run at too low of an ohm load at low volumes? shit i didn't know that, I was always told that the amp would see the resistance as too low and throw into protect mode automatically.
Cool.
Old Mar 31, 2007 | 08:11 AM
GradeA_TireFryer's Avatar
All American, rice eater!
maybe there kicker subs - and as they get older there spider gets sloppy
when he turns it up the cone flaps uncontroled and the voice coil leads are shorting out !
Old Mar 31, 2007 | 10:06 AM
King of Ricers
so far from chatting with him we have established the following:
Its a 4channel amp
He has 8ga power and ground
Only two channels are in use to drive a dual 4ohm sub
From this im betting that the sub is wired to 2ohms and that is the problem.
Old Mar 31, 2007 | 10:39 AM
P057's Avatar
isuck
Its a 4channel amp
bridged really only accepts 4 ohms doesn't it?
I really wanted to do this with my audiobahns and the phoenix gold, when i came across this roadblock..
