Need some help.
It looks to have a standard power/speaker harness plug, a J bus interface, and a changer interface that could also be AI-net or the brain control module.
I doubt it will run without the brain. If it would, you would at least need the power/speaker harness to connect power. You might be able to get away with soldering power wires to the two larger pins and the acc is the top pin next to the power pins.
-'03 GSX-R 750
-'03 GSX-R 750
No I don't, he got another one, and I think he used it for that.
Are you saying I could do it, but nothing would show up on the screen? That would defete the whole purpose of what I am trying to do. Or will I not be able to do stuff like videos? ( which I don't really care about right now. )
Would it be easier if I got like, a cd changer, and hooked that up?
That Clarion screen has a AM/FM tuner built in. It doesnt require a brain unit to work. You will need a harness. It will have power connections and speaker outputs. You will still need a CD/DVD player of some sort, you can get a Clarion CNEt changer that will interface directly, or any CD/DVD player and the adapter (adapter will run you around $50).
No real easy way to answer this, hope it helps....
By the way, here is the head unit I want to hook it up to.
I was planning on moving head unit down 1, and putting the tv where the head unit is now.
-'03 GSX-R 750
-'03 GSX-R 750
They go for ~100 on ebay - sell it and put it towards a new unit.
the headache of making it work would greatly outweigh the benefits. and it would be unreliable at best.
