tbspyder
So,
Two setups,
- one with JL 13w7 with an unnamed amp,
- Another setup with an unnamed 10" sub with the same unnamed amp (and apparently with a retail cost of $349)
In the SAME vehicle with the SAME wiring metered on the SAME term lab. I'm assuming with the sub facing the same direction.
The only variables being the box, and the sub. and possibly whether the box is ported.
ill put another $100 cash on top of Johns bet if anyone steps up...
Two setups,
So,
Two setups,
Two setups,
K4ts you can use my SAZ1500Ds, .35 FTW?
for the the sub if i get some of the cut (I'm pretty sure I know what $349 sub it is, if so I bought 2 12" ones loaded yesterday!)
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Loaded huh...either its pizza or FI.
I just got my first shipment of sundown amps...pretty impressive internals. The 1500 mono is rated at 1 ohm, warranted to 0.5 ohms, tested to 0.35 ohms, and strappable. If you get enough voltage, this thing will rock.
Toby
Toby
So,
Two setups,
Two setups,
Toby
hay toby that amp looks pretty bad ass, i might have 2 get one from you
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
