keeping speakers in a box
Old Dec 20, 2006 | 12:18 AM
Suicidal Racing's Avatar
Has V.I.P in HELL!
Default keeping speakers in a box
alright..i installed my home boys speakers today and they wont stay in the box..so fair both of them have jumped out the box..i've switched the screws and made sure i aint over tighting them and all so my ? is is there any thing i can use or any tricks where they wont come out..i aint even got the amp up up but the shit just slams still..the first time i turned the amp up some and one hooped out
the second time was just now when we had to cut it off because of cops then we turned it back on and it hooped out and it was a the other one.
i got to dynamate the trunk later on so i have to work on it no matter what.
Old Dec 20, 2006 | 04:33 AM
93ex's Avatar
Just Ledoux it!
Sounds like you are either using too small of screws, the wood has bene used enough times to ensure the holes are crap, or you arent even making contact with wood. Take out the subs, put down some gasket material, and then rotate the speaker about 5 degrees and try again. This is if the holes are fubared.
Old Dec 20, 2006 | 11:11 AM
Has V.I.P in HELL!
its a new box and i've already switched screws once..but ill get some gasket shit and try that.
Old Dec 20, 2006 | 12:03 PM
TBSpyder's Avatar
Fresh holes and 1.5" dry wall screws. If they don't stay in, you're doing somehting seriously wrong.
Old Dec 20, 2006 | 12:52 PM
TJElite's Avatar
Are the speakers tight in the holes? If the holes are cut too big, the screws will have less material to grab into. Even 1/8 of an inch too big can give you problems.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Dec 20, 2006 | 03:44 PM
P057's Avatar
isuck
what type of wood are you using..?
Old Dec 20, 2006 | 07:03 PM
Notladstyle's Avatar
King of Ricers
... wtf
notladstyle.blogspot.com
Old Dec 21, 2006 | 05:18 PM
jriggs's Avatar
is better than you™
just seal them in with some puddy and be done with it
Old Dec 21, 2006 | 08:27 PM
GradeA_TireFryer's Avatar
All American, rice eater!
Yea Just Use Some Puddy
Pirate Customs
Sound, Security & Style..... anything for your ride
Old Dec 22, 2006 | 12:17 AM
Has V.I.P in HELL!
there good now..it took a combo of things..now i just got to foam the back panel so it stops rattleing..i already dynamated the trunk
