Fuse Keeps Popping Plz Hlp
Old Oct 24, 2006 | 12:18 PM
Notladstyle's Avatar
King of Ricers
Originally Posted by custom240sx
It's good to have a seperate ground for your radio but it will work without a ground because the radio will use the antenna as a ground.
Eclipse, JVC, and clarion decks burn out the internal amplifier if you operate them without a direct ground.
Trust me I've had to replace decks because of bad grounds that took the internal amps with them. Good thing is you can just throw a 4channel amp on the RCA outs and call it a day.
notladstyle.blogspot.com
Old Oct 25, 2006 | 04:34 AM
djgizmo's Avatar
Sound Engineer for Hire
Thats the stupidist thing I've heard. Theres a reason WHY there is a ground for your deck. I myself wouldn't use the stock harness ground, but there is a need for the deck to be properly grounded.
"Your Music, Your Tunes"
