kicker solobaric L7 12" how many watts
Old Jul 22, 2006 | 07:13 PM
clostoyo's Avatar
whats a bout this one? http://cgi.ebay.com/BRUTUS-600-WATT-...QQcmdZViewItem, is that a good one, also how do i bridge the l7 to 1 ohm? its been a while since i messed around with systems
Old Jul 22, 2006 | 08:30 PM
Notladstyle's Avatar
King of Ricers
I would aim for 800-1000wrms if you want to get full potential out of that l7.
You will present a 1ohm load to the amplifier by wiring two 2ohm coils in parallel (both + together and both - together)
notladstyle.blogspot.com
Old Jul 23, 2006 | 04:28 AM
clostoyo's Avatar
thanks for the advive.
Old Jul 24, 2006 | 12:25 PM
clostoyo's Avatar
Default is this a good amp notladstyle?
Hifonics BXi 1206D Amp: Mono will this amp work good for the l7? and i will put the 2 cables coming from the + and put on amps positive and do the same for the - and that will give me 1 ohm, correct? just checking thanks
Old Jul 24, 2006 | 02:31 PM
King of Ricers
I just installed two L7s on a 1206 and they sounded great. It looks really gooid too. Go easy on the gain since you are only using one.
Old Jul 24, 2006 | 02:45 PM
clostoyo's Avatar
thats the one thanks for all the advice, ill keep you posted in my trucks progress for this setup
