Radio doesnt work... help?
Old Jun 18, 2006 | 07:39 AM
LOLWAT's Avatar
Registered-Honda-User
Default Radio doesnt work... help?
I bought a car an it has a cd player installed but its not getting power, nor is the cigarette lighter. Anyone know how to get power to it?
Old Jun 18, 2006 | 07:56 AM
TJElite's Avatar
Sounds like a fuse, since the cig lighter and radio constant are often on the same one.
Fuse might be called cig ligt, radio, or something like that. If you have a manual for the car, it usually lists all things powered by each fuse. Worst case, you'll need to check them all. This fuse is probably 20 amps...15 minimum, so you can narrow down your choices.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Jun 18, 2006 | 08:47 AM
LOLWAT's Avatar
Thanks dude! That would be awsome if that was all it was.
Old Jun 18, 2006 | 09:02 AM
TBSpyder's Avatar
I vote for fuse.
Old Jun 18, 2006 | 09:09 AM
LOLWAT's Avatar
That woulda been awsome if it was, but I just checked 'em all. Any other tips?
Old Jun 18, 2006 | 09:19 AM
TBSpyder's Avatar
Re-check them all with a multi-meter. Just because a fuse "looks" good doesn't necessarily mean it is. Check every fuse box as well.
Old Jun 18, 2006 | 09:38 AM
LOLWAT's Avatar
Its a crx I think it only has one fuse box. I don't have a multi-meter, but I do have some spare fuses I could just replace them all???
Old Jun 18, 2006 | 10:14 AM
TBSpyder's Avatar
Use a single 20amp fuse and swap one at a time until it works. If I'm not mistaken, those Honda's are know for blowing the fuse when an aftermarket deck is installed. Whatever size fuse it is, I'd replace it with one that is about 5 amps larger (so if it's a 15 amp, put a 20 amp in there).
Old Jun 18, 2006 | 10:33 AM
LOLWAT's Avatar
oh thanks! that would make sence because its a sony deck. But should i replace every fuse with on higher? I only have about 7
Old Jun 18, 2006 | 10:40 AM
P057's Avatar
isuck
usually those fuses come in packs of like 3 or 5, and cost at the max like $1.25, they're cheap as hell, go get a few and store em for a rainy day
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
