Suggestions plz...
King of Ricers
on
Suggestions plz...
Ok set 2 was made of 6 groups of 4LEDs in series. The LEDs started flickering after a few weeks of use.
Set 3 of my angel eyes has died. And I know they were water tight this time.
Basicly the sections of LEDs start flickering after 20 - 50 hours of use. they are 3.4v LEDs wired x4 to 14v in series. I've benched them in my house at 17v with no probs so what am I missing...
Set 4 will be regulated to 12v and will be a solid panel of LEDs(like a stop light, should be brighter than OEM foglights) and as such will be a bit more expensive to make so I thought I would request a little insight from the forums before I build them.
King of Ricers
on
nvm found the problem -> starter has a split second voltage spike somewhere in the 20v range, couldnt see it until I put a recording meter to it then I caught it. it wasnt time that was doin it, it was how many times I cranked the car.
King of Ricers
on
Originally Posted by GradeA_TireFryer
shouldnt your lights go out when you starter is engaged, so more power is avaible for the starter
