Final Verdict!
Old Jun 24, 2005 | 06:35 PM
Clifford's Avatar
weezin the juice
Default Final Verdict!
Ok, sorry for making a new thread, first of all. But I need some crazy help, so if someone can help me out, I'm going to list what I am going to get, than you rate it and tell me your opinion.
First thing-Kicker S10L7. Im just getting one, but I am buying two because my friend wants to go in on one with me.Link to 2-S10L7s
Next is the amp KickerLink to amp-Kicker KX600.1 AND IT IS REFURBISHED, but i figure it is like factory new. Also, would that amp be sufficient because it says "600w x 1 @ 2 ohms RMS 1200Wx 1 Peak " and my sub is 4 ohms, so would this be able to hit its peak at 1200 wts?
Next is wiring-Link to wiring kit
let me know what you think of al lthe listed above, also if it will all be compatable together(as in the sub/amp peak wise)
also I want to run a seperate battery to subs just to not kill my own, so what all would be involved in doing so, thanks!
cliff
Old Jun 24, 2005 | 09:11 PM
kpr10is's Avatar
Maximaniac
Yes, thats the best choice amp for that sub if your going with all Kicker. The amp will see a 2 ohm load which is what ie needs.
Youll need a couple fuseholders and a battery isolator or high current relay (200 amp), in addition to the power wire, to run the 2nd battery. You could do it without the isolator but I wouldnt really recommend it.
Not sure on your wiring kit since I didnt see a brand name.
kevin
Old Jun 25, 2005 | 05:23 AM
TBSpyder's Avatar
First off, forget "peak" or "max" power ratings on any amp...it's an irrelevant number. Assuming the sub is dual voice coil 4 ohms, you'll be able to wire everything up at 2ohms to achieve the 600w rms rating. And personally, I wouldn't waste my time on a second battery with only 600w, it's just not needed. If anything, simply upgrade your primary battery to an Optima red top.
Old Jun 25, 2005 | 08:40 AM
Clifford's Avatar
weezin the juice
Ya thats what ive come down to is just not getting the second battery, and Im looking around still for some better wires....
Old Jun 25, 2005 | 03:38 PM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Wires are not that important if they are the correct size really. I've run mostly all wal-mart wiring kits with no problems what so ever.
Old Jun 25, 2005 | 04:50 PM
integralsgreen's Avatar
25 bucks for a 4 ga. wire kit, gotta love walmart. if you do the walmart sosche wires, get just get some better rca's.
Old Jun 25, 2005 | 08:36 PM
Clifford's Avatar
weezin the juice
Thing is, I'm not all great with electrical stuffs, like I know how to hook the system up*hopefully hehe. but thats it. Any reccomendations? suggestions on anything? I would like to order this today/tomorrow...
Old Jun 25, 2005 | 08:41 PM
just dont do sumthin totaly weird like splice off your taillight for a power wire(ive seen someone actually do this, hehehaha he could olny listen to bass at nite) equiptment looks decient enough, if there any instal questions you have just ask most of us know what were doin.
