red or yellow top
wallmart battery aint cuttin it. its brand new but still when im idoling my car almost stalls out when my bass hits......time to get a better battery. so whats better an red top or yellow top battery? what are the differances? any input will help. thanks ~justin~
I would suggest testing the output voltage on your alternator you currently have. Also check the amperage. Face facts, if you arent making enough amps for the power you are drawing, its time for an upgraded alternator, this will set you back about 400-600. Stinger, Ohio Generator are quality names. You should have 2 1farad stiffening caps, golden rule is 1 cap per 1000 watts. Put a red top optima at the alternator, you should not need more than this. If you need more power, then put a yellow top deep cycle in the rear. Go to a quality shop for installations, with this amperage the chance of major damage and or fire is real. Mad Marks of Bradenton is a very credible shop with great product. Good Luck www.madmarks.com
Originally Posted by integralsgreen
i got a 2000 watt system
There's your problem right there. I'm surprised it's just your lights dimming and not your car turning completley off. You should be able to pick up a high output alternator at most good auto parts stores. Probably can find one a little cheaper online though, search. It would be highley recommended to uprgrade to a red top and atleast 4 guage wiring (from your new alternator to your new battery, and battery ground) at the same time. You'll more than likely notice your system is louder and/or cleaner as well with this upgrade. A battery alone just won't cut it, and I see capacitors as nothing more than a band-aid.
well it dose almost shut off when im idoling the rpms drop to almost 0 and the car almost stalls out. so what amprage alternator should i be lookin for or whatever? and also still not quite clear if a yellow or red top battery would be better. whatare the differances?
i would first up grade your power wire from ur battery to ur altenator if that doesnt work, second battery with a isolator, if that doesnt work bigger altenator.
What every happen to sex, drugs, and rock and roll. All we have now is AIDS, Crack, and Techno.
My religon is capitalism.
