red or yellow top
Old Mar 7, 2005 | 04:38 AM
93ex's Avatar
Just Ledoux it!
Originally Posted by RickitySlick
i would first up grade your power wire from ur battery to ur altenator if that doesnt work, second battery with a isolator, if that doesnt work bigger altenator.
the second battery is only useful if youre playing with the car off. and for the price of two yellow tops and isolator, he could have a new alternator, and be sure to cover the problem
Old Mar 7, 2005 | 05:07 AM
integralsgreen's Avatar
ill just go ahead n get a new alternator. how many amps should i be looking for?
Old Mar 7, 2005 | 07:11 PM
Bumpin Expo's Avatar
Reppin' the 813
does upgrading the power wire from the alt to the battery really make that much of a difference
I had a yellow top in my old explorer with a 1500.1 hifonics amp and 400 watt 2 chan hifonics amp and it ran great. The only thing is at nite there was a slight headlight dim when the bass hit full blast, other than that I had no probs
Old Mar 7, 2005 | 07:28 PM
TBSpyder's Avatar
It depends on the car. I've seen cars with 10 guage wire from the alternator and a battery the size of a lawn tractors from factory...that's obviously not going to cut it if you're running a 500+ watt amp with 4 guage wiring.
Old Mar 7, 2005 | 07:42 PM
Reppin' the 813
well I am about to run a red top (cant afford a yellow this time around). Stock wiring from alt to batt looks around 8 guage with thick strands, not really flexable. What do you reccomend?
Old Mar 7, 2005 | 08:30 PM
TBSpyder's Avatar
I'd go with 4 guage from your battery to your alternator, and also your battery ground to your chassis. It's usually a good idea to run atleast the same guage as your amp's wire.
Old Mar 8, 2005 | 03:36 AM
  #17 (permalink)
Reppin' the 813
yeah I run 2 seperate 4 guage wires for each of my amps. Looks like I am upgrading my alt to batt wire also, thanks
Old Mar 8, 2005 | 04:27 AM
  #18 (permalink)
93ex's Avatar
Just Ledoux it!
I have 4 guage from my alt to battery, I wanted to go 0 but I didnt have a terminal with 2 0 in/out.
Old Mar 8, 2005 | 05:16 AM
  #19 (permalink)
i mean how many amprage should a upgraded alternator put out?
Old Mar 8, 2005 | 12:25 PM
  #20 (permalink)
kpr10is's Avatar
Maximaniac
Ill be getting a 200 Amp from Can Am Motors on Florida Ave in tampa, once i get $400ish. Nobody makes one for my car but theyll make one in kit form for almost any car.
