IDQ sub which amp to power it?
Originally posted by adero
You should look into an amp that has a remote gain so that you can turn off the sub if need be. It helps when there are cops around and stuff.
Remote gain is a worthless toy really. Most decks nowadays have built-in sub controls. And if for some reason you ever wanted to cut the sub off, you could always wire a simple switch into the remote turn-on for the amp.
Originally posted by 93ex
or just turn the volume down
but then i can't hear it anymore. idk, i'm just screwed up, and would rather turn my sub down a little while i drive by a cop or something. And i like to be able to easily change the bass level depending on the song that i am listening to. it's just easier for me to use a gain.
But that's too easy!
