box
Old Aug 9, 2004 | 05:19 AM
93ex's Avatar
Just Ledoux it!
I like to brance any side more than 12 inches...
I use triangle braces, attach in the corners
Old Aug 9, 2004 | 08:08 AM
Bumpin Expo's Avatar
Reppin' the 813
+1
easiest to do
Old Aug 9, 2004 | 11:19 AM
TIM TIM TIM's Avatar
could be worse
lole the 4 corners of the box you just cut a triangle to fit in there and nail it in ?
aim:because tim said
Old Aug 9, 2004 | 11:35 AM
MDIFYTD's Avatar
Uber lurker
http://www.jlaudio.com/tutorials/bracing/index.html
Ill say i go by His and Al's thoery of "Your getting sprayed" Doesnt matter what it is. Grandma in the 1982 LTD is gettin the bottle.
Old Aug 9, 2004 | 11:44 AM
GsEclipse02's Avatar
so its ok if i brace it?
Old Aug 9, 2004 | 02:04 PM
93ex's Avatar
Just Ledoux it!
bah you know what i mean
in the edges
Old Aug 9, 2004 | 02:05 PM
  #17 (permalink)
dropcivic's Avatar
Redneck Proud
how is the placemtn of subs and port? Does it go woofer-woofer-port or is the port in the middle. If you do have a common chamber box, the subs should be the same distance from the port.
Honda certified Tech
Southern Pride not racism
Old Aug 9, 2004 | 02:06 PM
  #18 (permalink)
could be worse
thats what everyone said isnt it...
Old Aug 9, 2004 | 02:18 PM
  #19 (permalink)
Reppin' the 813
its sub sub port
Old Aug 9, 2004 | 02:26 PM
  #20 (permalink)
dropcivic's Avatar
Redneck Proud
bad then. The sub clossest to the port will have a different amount of airspace then the speaker furthest from the port. I recommand two seperate chambers
