can someone explain
Old May 18, 2004 | 06:16 PM
TBSpyder's Avatar
Originally posted by SSpiro
Even some of the most advanced or power-hungry setups can be done on a single battery. Possible that you may just need a larger alternator?
+1. Advantages of an additional battery are minimal on most everyday systems.
Old May 18, 2004 | 06:17 PM
TheTotaledMustang's Avatar
TTTRRRRUUUSSSTTT MEEEEE.........unless the 2 batteries have the exact same amount of life in them and are installed at the same time, they'll drain each other. If you wired 2 news ones, you'll be alright is they are the EXACT same kind of battery, if anything is different then they will drain each other unless you get a battery isolator (makes alt. stop charging 1 after is done and works on the other one) or a celinoid(check spelling) and that physically separates the 2 battery's connection when the car turns off (unless it malfunctions).
AND ON TOP OF THAT
.....batteries have internal resistance , although very small (say 0.01ohms), when factored into the equation of Resistance= Volts divided by Current......that small ass 0.01 can make the differance of up to 4 or 5 volts sometimes.
I had a 460cc lead acid and a 950cc lead acid battery of my 140amp alternator wired to my 1200+ watt system before w/ a 2.4 farad cap......and my volts were at 11.7idleing and sometimes got as low as 10.5 durring continuous play. (that was the mustang)
Now in my Maxima i have one reblimished 650cc deep cycle (23 bucks at interstate battery) of my 120amp? 115? (not sure, but it's smaller) and i hold 14.9 idleing and 14.0 solid while bass is dropping pulling 1500watts rms. NO CAPACITOR
IMO from experience and reading about it car stereo magazine, unless you're going all out 3000+ watts rms i dont think you need an extra battery, if you're concerned get a nice optima or stinger and it'll do fine. my 23 dollar reblimmy is still pounding after 10 months of abuse......
she said they call 15% blowjob tint for a reason
Old May 18, 2004 | 06:55 PM
Bumpin Expo's Avatar
Reppin' the 813
^ yeah what he said!
Old May 18, 2004 | 08:02 PM
Mmmm Rice's Avatar
It's the man
i put 2nd battery's in cars at work like every day and you dont need an issolater and if you uesd a dioed it would need to be a big one you can use a big realy like a 100 -200 amp realy but you dont need that. and i find it is best to use a deepcycel battery, the stinger is good but we have 5 in one of the vans we put a system in and they dont like to stay at 12 volts nop matter how much you charge them. a adding a battery wont drain your old one just dont play your system with the car off. any system with more than 100 amps of curent draw needs an extra battery,
Iam a car stereo installer. if you have stereo questions you can Email me willthisfitinyrmouth@hotmail.com
or get me on aol instant messenger dirtybird097
Old May 21, 2004 | 10:21 AM
ya if you go over 100 amps draw you need electrical upgrades like a new alternator (best but most exspensive), next best is a really good battery, but if you're cheap like me get a nice size dep cycle and slap on a capacitor......
