Wire two subs to mono or 2 ch amp?
Old Feb 25, 2004 | 09:17 PM
PiMpSoLo's Avatar
Default Wire two subs to mono or 2 ch amp?
On all the sites they say to use a mono amp for two subs, in my experiance, everyone I know has both subs wired to a bridged 2 channel.
I was looking at getting maybe two kicker comps which are dual 2 ohm. Would it be wise to hook two of these subwoofers to a single 2 channel amp? and how would I? would I do it parallel, then hook them to the +R and +L or what?
On the flip, I was also looking at two 4ohm svc subs, would that be smart to hook to a 2 channel amp?
Old Feb 26, 2004 | 09:36 AM
93ex's Avatar
Just Ledoux it!
the mono amps are usually class D, whereas 2 channels are a/b.. class D is more efficient, so its easier onthe ol charging system to run class D mono amps for subs
Old Feb 26, 2004 | 10:56 AM
TBSpyder's Avatar
Go mono. Less drain on your electrical system, and they usually are stable to a lower impedence load...which means more wiring possibilities and more power.
Old Mar 24, 2005 | 03:26 PM
Rattltrunk's Avatar
PS3 Tag- uSMc Rattltrunk
Swweeettt
2009 Nissan Armada 4x4
2012 Ford Fusion
Giants, Mets, Knicks Fan!
USMC Veteran
Love my Wife in the Avatar!
Old Mar 27, 2005 | 02:02 PM
Rattltrunk's Avatar
PImpSolo, hows it going along, the system?
2012 Ford Fusion
USMC Veteran
Old Mar 27, 2005 | 02:04 PM
93ex's Avatar
Just Ledoux it!
well this is over a year old....
