need some help
Old Nov 16, 2003 | 04:06 PM
GTSdriver's Avatar
Default need some help
i have 2 12's in a 2002 explorer and ive checked and rechecked the wiring but the bass still cuts out every once in a while for about 5 seconds and then comes back fine.....so if anyone has any advice id appreciate it
Old Nov 16, 2003 | 04:38 PM
Bumpin Expo's Avatar
Reppin' the 813
what kind of subs, amps, HU
Old Nov 16, 2003 | 05:47 PM
93ex's Avatar
Just Ledoux it!
volume up high?
Old Nov 17, 2003 | 10:45 AM
Reppin' the 813
the only reason i ask is cuz my old shitty jensen amp would overheat if turned up too much so if u had a cheap amp thats prolly why
Old Nov 18, 2003 | 01:25 PM
GTSdriver's Avatar
i have a jl 300/2 and two audiobahns but maybe i do need a better amp....any suggestions...thnks
Old Nov 18, 2003 | 07:30 PM
TBSpyder's Avatar
I doubt it's your amp. How hot does it get when it cuts out? I'm guessing it's a ground. Has it done this since you installed it, or has it worked perfectly up to this point?
Old Nov 18, 2003 | 07:51 PM
93ex's Avatar
Just Ledoux it!
What is the ohm load?
Old Nov 19, 2003 | 11:46 AM
GTSdriver's Avatar
yea i was hoping it wasnt the amp....but ill check the ground..and the subs require 4-6 ohms
