ls vtec
Old Jan 10, 2012 | 07:57 AM
acuralsb18's Avatar
Default ls vtec
whats up tr just wondering what are some parts needed for the build i want a little over 230 hp. Im building a dd so i still want a/c so i just want something mild and was wondering like what size injectors i would need and if i needed to do anything to the block pretty sure im going to have to build the head but lmk and also what head should i use b16 or gsr
TR "Old Skool DA" Member #17
Old Jan 10, 2012 | 08:10 AM
SuburbanNoize's Avatar
Cold Ass Honky
You could do a stock rebuild, throw a 50 shot on it, and be at your goal. As for the head choice, It doesnt really matter, both are way better than an LS head.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Jan 10, 2012 | 10:32 AM
acuralsb18's Avatar
tru but i really dont want to use nos i want a n/a
Old Jan 11, 2012 | 06:13 PM
Paulino's Avatar
Not harsh, just truthful
A little over 230 whp out of a b series. To make it the easiest for you, start with an ITR head and a B20 block. Do some research on honda-tech.com bro. It will help your life. Good luck dude. I have an ls/v build that will see 220-230 whp, check it.
https://www.tamparacing.com/forums/p...ld-thread.html
Old Jan 16, 2012 | 06:45 PM
elmcityrican's Avatar
yes like Paulino said, check out there are some real good threads on honda-tech stickied.. its almost like a manual.. im with you in that same boat.. im still missing a few parts left (headers/intake/TB/cam gears) but got most of the main things out the way.just got to figure out what kind of ecu and stuff..but its a work in progress..
Old Jan 17, 2012 | 06:57 AM
Paulino's Avatar
For header I suggest the Skunk2 Alpha series header, $360 shipped for a name brand , dyno proven header sounds pretty good to me. As for TB, honda-tech holds a special on Omni Power throttle bodies either 68 or 70 mm for $100 shipped to your doorstep. As for intake shoot for a 2.5" or possibly 3", and the cam gears from any aftermarket company will suffice, they show up lightly used on here all the time. Good luck you too!
Old Jan 17, 2012 | 07:27 PM
Thanks man, yea the header is the only one that I was having a hard time deciding on i got buddy club 3+ cams (didnt know if a 4-2-1 would suit me better w/ those cams or a 4-1 would be just as good) .. Im trying to get this build done with so i can actually drive it after waiting for a year already! lol..so don't know if I will have the $360 for that alpha header now, maybe a bit later on.. i did see it on ure thread though, looks sick!.. thanks for the tips, def will check out the omni TB..
twopointzero
For Sale/WTB Honda & Acura
17
Oct 3, 2011 05:19 PM
chucky12si
6
Aug 12, 2011 09:31 AM
sullivanracing06
5
Nov 26, 2009 05:24 AM
euroexport
Jan 28, 2009 11:37 AM
edmel89
Dec 12, 2008 01:32 PM
