help gsr smoke high rpm
Old Aug 15, 2011 | 08:45 AM
evo911's Avatar
Default help gsr smoke high rpm
My gsr runs good it started to smoke at maybe 5 rpm and up Idk y it doesn't over heat at all it is white smoke it isn't antifreeze Idk wat it is car doesn't lag it runsgood even when it smokes but it smoke a lot when u get on.it Wat could it be ? Piston rings ?
Old Aug 15, 2011 | 10:00 AM
evo911's Avatar
Old Aug 15, 2011 | 10:52 AM
Jibin's Avatar
TR User
Maybe a blown headgasket
Old Aug 15, 2011 | 11:45 AM
evo911's Avatar
wouldnt i over heat tho
Old Aug 15, 2011 | 07:17 PM
EF-C's Avatar
Is the car consuming any oil or antifreeze? Take the spark plugs out and compare them to see if you see any physical difference in them. You can also buy 4 NGK spark plugs and put them in and compare them in a week. Open your oil cap with the car on and see if you have a lot of blow-by (a lot of blow-by would indicate worn out piston rings).
Future Project
Old Aug 17, 2011 | 10:14 AM
evo911's Avatar
blow by as in smoke coming out or air
Old Aug 17, 2011 | 12:15 PM
EF-C's Avatar
Both. Air will be during the compression stroke, Smoke during the explosion.
Future Project
krazyone
Mar 3, 2010 07:14 PM
Aoshi
Jan 17, 2010 09:54 AM
Sippi
May 13, 2007 12:32 PM
05stisilver
Car Audio For Sale
May 9, 2007 10:10 AM
74javelin
Mar 12, 2005 05:48 PM
